Removing Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2017, 02:06 PM   #1
Rewards Points: 14
Removing Flange
http://dealsinohio.com/buzzer/pics/3.JPG
Is this a cast iron flange?
Advice on how to remove it?
The inner black circle is the pipe the flange attaches to?
ClevelandFlips is offline   Reply With Quote
Old 05-06-2017, 05:18 PM   #2
Rewards Points: 14
Re: Removing Flange
Bump!
Old 05-06-2017, 06:20 PM   #3
Property Mgt/Maint
Rewards Points: 8,202
Re: Removing Flange
Wow, talk about patience. You waited a month to bump.
Regarding the ring. It probably is cast iron or possibly brass. Can not tell. It needs to be cleaned up. Looks like the wax ring seal is still stuck to it. You can buy repair rings or replacement rings. There are several options available, just depends on whats left.
Yodaman is offline   Reply With Quote
Broken closet Flange Paul8434 Plumbing 2 12-04-2012 07:08 PM
Removing a plastic toilet flange insert DeSOB Plumbing 1 07-04-2011 10:50 AM
cast iron flange Jrebhun Plumbing 2 09-06-2008 12:45 PM
Removing old toilet flange craftycas Plumbing 3 02-22-2005 11:59 AM
