Remove Spout Piping From Tub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2016, 08:29 PM   #1
Rewards Points: 175
Remove Spout Piping from Tub Faucet
Hi All!
I've got a very old tub faucet that has a galvanized pipe connection to the spout. The pipe has started to rust out. I plan to replace it with a copper pipe, but first I have to remove the old pipe. My only hesitation is that the pipe seems to have been installed with some kind of "sealant". I don't know if I need to do something special -- e.g., heat the pipe first -- before I use a pipe wrench to unscrew it from the valve body.
I've included a pic, and that creamy stuff sitting on top of 90 degree elbow is the "sealant" I've mentioned above. (Sorry about the horizontal display -- my viewer shows it vertical ...)
As always, your help is greatly appreciated.
Richard
Remove Spout Piping from Tub Faucet-hall-bath-bathtub-plumbing-20160220_134335-.jpg
RichardZ is offline   Reply With Quote
Old 02-21-2016, 09:43 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
I would replace the whole shower valve.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
joecaption (02-22-2016)
Old 02-22-2016, 05:41 AM   #3
Retired Moderator
Rewards Points: 7,174
That is pipe dope---and will not stop you from unscrewing the nipple--make it easier,actually.
Gymschu (02-22-2016)
Old 02-22-2016, 03:50 PM   #4
Rewards Points: 175
I agree, and plan on doing that when the bathroom is remodeled. This is just an immediate fix ..
Old 02-22-2016, 03:57 PM   #5
Rewards Points: 175
oh,mike, that's what I initially thought, but it's a bit crumbly. Does pope dope turn that way (it has been 50 years ...)?
Richard
Old 02-22-2016, 04:11 PM   #6
Rewards Points: 5,452
Chalk up another + for Teflon tape. A word of caution with the tape. Some female fittings can be cracked because of a lack of friction.
SeniorSitizen is offline   Reply With Quote
Old 02-22-2016, 06:20 PM   #7
Retired Moderator
Richard
The old pipe dope looks exactly like that!
Good luck--
Old 02-22-2016, 07:14 PM   #8
Rewards Points: 582
don't use copper....just replace what you have with brass ..nipple and 90
Old 02-22-2016, 07:37 PM   #9
Rewards Points: 175
Thanks everyone! I'll let you know how it goes.
Richard
Old 02-22-2016, 07:45 PM   #10
Rewards Points: 582
welcome
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (02-22-2016)
Tags
bath faucet , spout piping
Supply line from old faucet stuck in copper piping clm55 Plumbing 2 12-31-2012 12:55 PM
Right tool to remove cartridge of single handle bath sink faucet? darsunt Plumbing 2 05-20-2011 10:01 AM
how to remove "roman tub" faucet? tarheelblue Plumbing 9 07-26-2010 09:50 AM
Spout problem on old double handle faucet RW Johnson Plumbing 2 04-12-2009 06:25 AM
Calcified faucet spout and handles doit! Plumbing 1 12-09-2008 01:11 PM
