Remove Plastic Toy From Toilet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2015, 07:04 PM   #1
Rewards Points: 294
Remove plastic toy from toilet?
What is a good way to remove a plastic toy stuck in the toilet.
I have taken the toilet off and pored a hose in it, but there must be an easier way, some kind of grabber tool.
Mikeron is offline   Reply With Quote
Old 12-17-2015, 07:15 PM   #2
ZTMAN's Avatar
Rewards Points: 604
If the toilet is off , run a snake up from the bottom. If that doesn't work, its porcelain. Flame on
ZTMAN is offline   Reply With Quote
Old 12-17-2015, 07:16 PM   #3
Rewards Points: 5,664
Block the toilet up and determine if a length nylon cord, or similar strength strong string, will flush through past the toy by dumping a pail of water in. You did keep one end in your hand didn't you?
Next tie a rag to the flushed through cord and pull the rag backward through dislodging the toy. If the cord rag combo is insufficient, a rope can be taken through being you have the string in place and tie a larger rag onto the rope until that little feller gives.
Remember that Clove Hitch knot? Works great to secure the rag.
Leave about a 3 ft. length of cord or rope tail so if it won't pull through it can be pulled back.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
Arlo (12-19-2015), Yodaman (12-17-2015)
Old 12-17-2015, 08:31 PM   #4
Rewards Points: 582
have you tried this ....
Old 12-17-2015, 09:52 PM   #5
JUSTA MEMBER
Rewards Points: 3,274
There's also a tool called a Mechanic's Fingers, it is a flexible spring thing with a push button that has another shaft inside it to go into small places to grab onto things that are dropped where you cannot reach.
It is about 2 feet long, and should get to the toy.
ED
de-nagorg is online now   Reply With Quote
Old 12-17-2015, 11:00 PM   #6
Rewards Points: 276
Someone dropped a comb down our frat house commode. Tadpole and Birdman had the commode off and after fishing for it for an hour plus they broke for lunch. In the meantime another made use of the toilet. Tadpole cradled the bowl, walked down the steps, out through the formal foyer and smashed it center of 34th & Powelton. To add insult, we fined him $50 bucks.
throrope is offline   Reply With Quote
Old 12-18-2015, 06:42 AM   #7
Rewards Points: 8,349
A hammer was the only tool capable of getting the lid from an eye liner case out. The stupid thing was stuck like a hinge. Sometimes it would flush and sometimes it would not.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 12-18-2015, 07:00 AM   #8
A butter tub lid works the same way. Reminds us of an erratic butterfly valve. That's where I learned to go bigger rag rather than the hammer blow in the side right where that kid told me to pop it. But the hammer did reveal the culprit and warrants a new toilet of course.
Toilet Shut Off Valve/Chrome Sleeve, How to remove ZTMAN Plumbing 10 03-07-2015 08:36 PM
Remove scuffs on a plastic bath havago General DIY Discussions 15 10-19-2014 06:07 PM
Remove plastic before drywall installation? avgor Drywall & Plaster 6 01-23-2012 08:03 PM
Help with stink coming from Toilet area. Integraoligist General DIY Discussions 9 11-16-2011 05:16 PM
How to remove paint from plastic? cevamal Painting 3 09-14-2009 09:44 AM
