Remove Old Cast Iron Pipe Held In By A Fernco Gasket - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By Gregsoldtruck79
Old 10-19-2018, 10:04 PM   #1
Rewards Points: 2
Remove old cast iron pipe held in by a fernco gasket
HI, I need to remove a pipe held in by a fernco gasket to shorten a cleanout pipe but the gasket won't budge. I tried to lift the pipe off, I drilled the edge of the gasket but nothing seems to penetrate this old gasket. If you know of a way to remove a pipe that is in a fernco gakset, I would appreciate the advice. Thank you.
chichi12 is offline   Reply With Quote
Old 10-19-2018, 10:27 PM   #2
Guapo
Rewards Points: 11,950
Re: Remove old cast iron pipe held in by a fernco gasket
Is it a gasket or a coupling? Can you post some pics?
Guap0_ is offline   Reply With Quote
Old 10-20-2018, 05:17 AM   #3
Rewards Points: 574
Usually a long blade screw driver pushed under it and pried out a bit will work. Insert the screwdriver as you go around the pipe parallel to it.
Space the inserting of the screwdriver about an inch apart and go all the way around the pipe prying up on the gasket, to breaks its bond to the pipe.JMO
joecaption and Guap0_ like this.
Disclaimer: Any of my replies, advice, product recommendations, or projects that I have done that I post on this forum, are just for informational purposes only. Any reader choosing to use my postings, advice, product recommendations, or choose to duplicate any of my projects for their own use...are doing so at their own risk.
Gregsoldtruck79 is offline   Reply With Quote
Old 10-20-2018, 12:01 PM   #4
Rewards Points: 1,222
Probably a donut.
Old 10-20-2018, 02:58 PM   #5
Rewards Points: 6,649
Only done it once and hope never again. Cut the pipe flush with the gasket, stuff a rag or two in the pipe to keep bad stuff from going down the drain, then either cut or break the pipe. Cast iron pipe will shatter if hit often enough. The trick is to break what you want to break.
A diamond wheel will cut the pipe if you can get it inside the pipe.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Cast Iron Pipe kbartels Plumbing 2 10-30-2016 07:50 AM
Cast iron pipe support strapping and sway bracing Deck Plumbing 4 05-26-2016 07:03 PM
Drilling into concrete foundation to remove cast iron drain pipe Remmy Plumbing 2 12-09-2012 05:33 PM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 07:41 PM
