Remove A Broken End Of A Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2015, 05:08 PM   #1
Rewards Points: 4
Remove a broken end of a copper pipe
Can anyone explain how to remove a broken end of a copper pipe thats sweated into the valve?
bigvern79 is offline   Reply With Quote
Old 09-27-2015, 05:30 PM   #2
Rewards Points: 18,976
Got a picture?
Old 09-27-2015, 05:35 PM   #3
Retired Moderator
Rewards Points: 7,174
If you can grab any of the stub with a pair of vice grips--then heat it up and pull out the stub---
It might be easier to cut out the valve and replace that along with the broken stub.
Old 09-28-2015, 08:12 AM   #4
Rewards Points: 4
Yes that's what I'm gonna do .at least to get a better grip on the broken piece
Removing pipe wrap from 1/2 inch copper pipe steve3847 Plumbing 8 04-19-2015 08:33 AM
Connecting PVC Sprinkler Pipe to Copper House Main Line fritzycat1 Plumbing 6 05-15-2013 03:25 PM
How to Estimate Water Flow Rate in Copper Pipe arskiracer Plumbing 12 04-15-2013 08:50 PM
Compression Valve for leaky pipe (not copper)? DIYsoon2Bpro Plumbing 11 01-18-2012 06:40 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
