Relocating Vent Pipe From Kitchen Soffit - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2015, 03:52 PM   #16
A "Handy Husband"
rjniles's Avatar
Rewards Points: 886
Originally Posted by slowmotion View Post
Just a crawl below so no other lines. If I reduce the vent to 1.5" below the top plate, at what point do I transition back to 2"?
If you can access it, I would go back to 2" in the vertical section thru the roof.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
slowmotion (07-26-2015)
Old 07-26-2015, 05:52 PM   #17
Rewards Points: 56
So here is what I ended up doing... I reduced the pipe from 2" to 1.5" and made the 90 degree bend. Glad this was recommended because the 2" bend would have been too large to allow the drywall to extend to the corners - it will be tight enough with the 1.5" bend. I tried to hole saw it and you were correct that there was enough play if I could have drilled the hole in the center of the top plate for that to work, but I just couldn't get it to work. I decided instead to go for the notch and have installed a Simpson plate (not pictured) for reinforcement over the opening after installing the pipe.
Thanks for all the suggestions!
slowmotion is offline   Reply With Quote
The Following User Says Thank You to slowmotion For This Useful Post:
TheEplumber (07-26-2015)
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Vent Pipe camel604 Plumbing 2 03-06-2011 08:19 PM
vent stack pipe in kitchen Tena Plumbing 2 10-11-2010 05:03 PM
Run vent pipe in soffit along with duct trunk acerunner Plumbing 1 09-28-2010 08:06 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
