Relocating Toilet Drain Pipe - 90 And 45 Degrees - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By TheEplumber
  • 2 Post By Ghostmaker
  • 1 Post By BIG Johnson
Old 05-26-2017, 08:50 AM   #1
Rewards Points: 62
Relocating Toilet Drain Pipe - 90 and 45 degrees
I am doing a bathroom remodel at my house. I am moving the location of the toilet and after cutting the slab the handyman came up with the attached configuration, see photos, for the toilet drain abs pipes. He is using a 90 and 45 degrees right next to one another. Is that OK? If not can I do three 45 degrees? I need the flange to be at the same location I have it now.
Any plumber response would be much appreciated.
Relocating Toilet Drain Pipe - 90 and 45 degrees-pic001.jpg   Relocating Toilet Drain Pipe - 90 and 45 degrees-pic002.jpg
Al11 is offline   Reply With Quote
Old 05-26-2017, 09:11 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 248
Re: Relocating Toilet Drain Pipe - 90 and 45 degrees
For starters, the horizontal 90 is a vent 90. It is not an approved drainage fitting. Only for dry vents. It's radius is way too tight. It should be replaced with a long sweep.
Second, you should have a plumber doing the work.....or yourself. My state has laws against handy man plumbing- it can get very expensive to all involved.......
JERRYMAC likes this.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Ghostmaker (05-26-2017), JERRYMAC (05-28-2017)
Old 05-26-2017, 09:13 AM   #3
Plumber
Rewards Points: 248
Revisiting the picture- cut the slab back further and use a 45 and/or 22 and get rid of 90
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 05-26-2017, 09:53 AM   #4
Rewards Points: 777
If it were mine i would find the main and cut in a new wye. You already have the floor tore up.
ct18 is offline   Reply With Quote
Old 05-26-2017, 10:15 PM   #5
Rewards Points: 1,930
Under IPC the 3 inch or above 90 degree fitting cannot be used horizontal to horizontal. I make real plumbers fix that one.
Duh Inspector....
JERRYMAC and Mike Milam like this.
Old 05-27-2017, 04:45 AM   #6
Rewards Points: 898
If I were doing it, I'd buy a few each 22, 45 & 60 and a new flange to see if I could route it over without any 90's. Play around with them dry. Plumbing fittings don't have to all be positioned at 45 & 90 to one another.
If I couldn't do that, I'd break up a little more concrete and dig so I could at least swing the 90 coming off the flange over to allow the use of 1 LS 90 or 2 45's. It would only take a few more inches.
BIG Johnson is offline   Reply With Quote
Old 05-28-2017, 07:41 PM   #7
Rewards Points: 62
Thank you for your responses. It really helped and makes sense.
Do you know if using three 45 degrees next to one another resulting in a total of 135 degrees would be OK. There is a drop of an inch along the total 135 degree turn. The flange needs to be moved slightly. See attached photo.
Old 05-31-2017, 02:44 PM   #8
Rewards Points: 794
I think the question that is being asked by a few of the pros is: can you cut the main pipe back a little more and run straight into it with a 45 or 22? That looks like a new wall. What is behind that wall? Can you take the sheetrock and framing off and cut this pipe back another foot?
I hate to ask, but is it vented properly?
B
Beepster is offline   Reply With Quote
Old 05-31-2017, 03:11 PM   #9
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,834
You could get some of that flange movement back with an adjustable offset flange.... just FYI.... if it matters
MTN REMODEL LLC is online now   Reply With Quote
Old 05-31-2017, 04:07 PM   #10
Rewards Points: 62
Thank you very much for your responses. Never heard of the offset flange!!! It makes a whole world of difference. I will just use two 45 degrees instead of three and then use it with the offset flange and get it close to where I need it to be. Venting is original and I have just relocated the toilet location by about 2 feet.
The Following User Says Thank You to Al11 For This Useful Post:
Auggie56 (05-31-2017)
Old 05-31-2017, 04:51 PM   #11
Auggie56's Avatar
Rewards Points: 150
I have to thank you for starting this thread AI11, as we were just talking about doing this very thing.
Auggie
Auggie56 is offline   Reply With Quote
Tags
drain assembly , toilet flange
Adding new shower drain to toilet drain? w layout pics BNR34RB26DETT Plumbing 25 02-11-2015 09:55 PM
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 09:24 AM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 08:14 PM
toilet drain pipe is crooked on new construction smcmurrey Plumbing 5 12-24-2008 08:32 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
