Relocating Section Of Water Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2017, 08:16 AM   #1
Rewards Points: 20
Relocating section of water pipe
Iím relocating about a 6 foot section of cold water pipe, and a 6 foot section of hot water pipe to give my new staircase more clearance. My question, do I need this fitting that the arrow is pointing to on the attached image? Itís on the cold water pipe. If so, what is that fitting or valve called?
veeps is offline   Reply With Quote
Old 10-31-2017, 09:32 AM   #2
47_47's Avatar
Rewards Points: 320
Re: Relocating section of water pipe
That may be a bleed. Does it look like what's on the side of this valve?
47_47 is offline   Reply With Quote
Old 10-31-2017, 09:45 AM   #3
Rewards Points: 20
Yes there is a cap.
Old 10-31-2017, 10:18 AM   #4
47_47's Avatar
Rewards Points: 320
If it's a bleed, I don't really see a good reason for it. I usually only see them on the side of a valve to drain the water from the line, when the valve is closed. A plumber should stop by later and confirm.
Old 10-31-2017, 10:46 AM   #5
Rewards Points: 1,602
Do those bleed valves ever leak? They scare me for some reason.
mikegp is offline   Reply With Quote
Old 10-31-2017, 11:16 AM   #6
Rewards Points: 20
My father-in-law is a plumber and Iíll have him look at it. in the past when weíve done any plumbing we just bled the system by opening all the faucets.
Old 10-31-2017, 11:59 AM   #7
47_47's Avatar
Rewards Points: 320
Never had one leak, There is a gasket under the cap. They are on my inside shut-offs for the outside hose bibbs. Turn off the inside valve, open the outside valve, remove cap and water drains from the line.
Old 10-31-2017, 12:41 PM   #8
Rewards Points: 2,632
You could get rid of it if you want. Your diagram shows a laundry at end of the line; could be used to drain that line by opening it up there.
bob22 is offline   Reply With Quote
Old 10-31-2017, 02:29 PM   #9
Rewards Points: 777
Its a drain coupling so if you ever had to cut in a fitting on all that flat piping you could drain some of it.
ct18 is offline   Reply With Quote
Old 10-31-2017, 03:35 PM   #10
retired framer
Rewards Points: 15,178
They make insulation for pipe.
https://www.lowes.ca/building-suppli...pe-insulation/
Old 11-02-2017, 06:45 AM   #11
Rewards Points: 18
Depending on how you are going to read route the pipe, you may wish to consider keeping that bleeder. With horizontal copper pipe, if you ever have to solder in a new fitting on that horizontal run, you need a way to get ALL, or virtually all of the water out of the pipe in order to solder in the new fitting. My guess is that bleeder was put there because that is a low spot in your horizontal. There are other ways to solder a fitting into a horizontal pipe using bread, but that is for a different day. If you are replacing the existing pipe with pex, or if you are using shark bite fittings for the new pipe, this is not an issue and you can remove the bleeder.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 11-02-2017, 08:37 AM   #12
Rewards Points: 20
It will be getting re-routed with copper.
Old 11-02-2017, 08:50 AM   #13
Rewards Points: 18
Are you going to solder in fittings or are you going to use sharkbites?
Old 11-02-2017, 09:21 AM   #14
Rewards Points: 20
I think I will take that bleeder out and put one bleeder on the low spot on each of the rerouted lines. The rerouted lines will be lower than the original pipe location to clear the other plumbing and electrical in the area.
Old 11-02-2017, 09:46 AM   #15
Rewards Points: 18
If you are going to be left with horizontal pipes, and are going to solder new fittings, I would suggest adding a bleeder as close to the lowest point of both pipes.
Shark bites are somewhat expensive, but, when you consider the time savings, to me, they are well worth it. It took me a long time to make the transition, but I now run all new supply plumbing using pex. Once I did my first house using it, I never looked back. It is a rare occasion now when I solder.
Good luck!
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 01:53 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
