Relocating Pressure Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2015, 11:43 AM   #1
Rewards Points: 46
Greetings!
New Homeowner looking to learn and improve my home!
My home was built in '51 with a 90' well drilled in the basement.
They added an addition with a poured 5' basement foundation, but they didn't add a good way to access it. The only access to it is over the well through a hole, so i wish to relocate my pressure tank, build a platform over the well so I can access the other side.
Here is the current setup. The well is to the right of the tank in the picture and you can see the pump clearly.
I want to move it maybe 5 feet to the right where those shelves are located. I will remove the shelves.
My question/concern is: If I leave the pump where it is and simply add the necessary plumbing to relocate the tank then will it create too much extra strain on the pump? I would assume it is only going to be 8-10 feet of additional plumbing.
awitte58 is offline   Reply With Quote
Old 12-28-2015, 12:37 PM   #2
Civil Engineer
Rewards Points: 5,246
Moving the tank 8 - 10 feet will produce only a small additional pressure loss in the system, should be no problem, make sure you size the pipes correctly. That looks like galvanized piping, generally a bad choice for water piping due to corrosion, copper or PEX is better. If you go copper make sure you use a dielectric union to connect the galvanized to the copper.
Old 12-28-2015, 02:38 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,670
Move the tank into the new crawl space out of the way.
Old 12-29-2015, 08:39 AM   #4
Rewards Points: 46
Good to hear! By sizing the pipe correctly do you mean matching what is there or is there some special calculation that needs done?
And I would love to put the tank in the crawl space, but I will have to see if it is short enough to fit back there. It is a tall tank.
Old 12-29-2015, 10:53 AM   #5
Civil Engineer
If the system is working OK now, just match pipe size, but as I said, I recommend copper or PEX, not galvanized.
Old 12-29-2015, 11:35 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,046
Ayuh,.... You can always buy a new pressure tank, that fits where ya want it too,....
To really clean up yer cubby, buy yerself a submesible pump, 'n drop it down the hole,...
Get rid of the pump ya got,...
You'd have a flat steel plate with 1 pipe, 'n 1 wire connection there,...
Run 1" Pex to the tank, 'n beyond to marry up to the house's system,...
Old 12-30-2015, 08:27 AM   #7
Rewards Points: 46
How can you install a submersible pump in an indoor well? All of the videos and stuff I have watched have 1" pipe to lower the pump into the well....
How do you know how deep your well is? Is there a way to test it?
Thanks for the info guys! I'm doing a lot of reading.
Old 12-30-2015, 08:36 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 810
What is the diameter of the well casing? Is there 1 or 2 pipes going down the well?
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 12-30-2015, 08:50 AM   #9
Rewards Points: 46
I do not know the diameter of the well casing. Also I can only see 1 pipe coming out of the well cap. I haven't taken the cap off to inspect.
Old 12-30-2015, 09:35 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 810
A single pipe system with an above ground pump has a suction limit of about 25 feet. The well can be deeper than that but the water level can.t be more than 25 feet below the pump.
Old 12-30-2015, 09:57 AM   #11
Bondo's Avatar
Ayuh,.... A fishin' line, 'n sinker,..?? a string, 'n a big ole nut,..??
Drop it down to water level, pull it out, 'n measure it,...
Drop it in down to the bottom(aka; slack line), pull it out, 'n measure,...
A submersible pump can be hung on 1" plastic line, the wire, 'n a rope to hold the weight,...
Just be sure to use a few torque arresters just above the pump to stop wear on the line, wire, 'n rope,....
Old 01-07-2016, 03:42 PM   #12
Rewards Points: 46
Good news. I will measure it soon. I am trying to figure out exactly what I am going to do and get the stuff necessary before shutting off the water.
This sounds like something I would be interested in. Depending on how deep tthe well actually is.
Does anyone have a link to better reading on how to do this? Installing submersible pump and wiring it up etc.
Old 01-07-2016, 05:27 PM   #13
Bondo's Avatar
Ayuh,.... Lotsa ways to do it on google,... 77,300,...
Old 01-07-2016, 05:29 PM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 810
First thing you need to do is determine the well diameter.
Can I install a pressure tank like this? cjizzle Plumbing 0 10-04-2014 07:14 PM
Elevated pressure tank rich_kildow Plumbing 4 12-29-2013 04:10 PM
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Pressure tank cycling sontavas Plumbing 8 12-10-2012 07:04 PM
pressure tank problem? steel Plumbing 14 07-03-2008 02:06 PM
