Reinstalling Inlet Filter On A Bosch Aquastar Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2016, 04:36 PM   #1
Rewards Points: 144
Reinstalling inlet filter on a Bosch Aquastar tankless water heater
I have a Bosch Aquastar tankless water heater Model GWH 1600H
http://www.bosch-climate.us/files/20...sh_05.2007.pdf
I decided to clean the inlet water filter as advised in the manual. I got the filter out OK but can't seem to get the retaining clip to go back in place.
The manual mentions a "threaded" bushing but when I inspect the bushing I see no such threads.
What is the secret of getting that retaining clip back in place?
spinnaker15136 is offline   Reply With Quote
Old 10-02-2016, 04:46 PM   #2
Rewards Points: 144
Re: Reinstalling inlet filter on a Bosch Aquastar tankless water heater
I am guessing the retainer clip is supposed to go on top of the bushing? Perhaps I am not getting the bushing fully into the housing?
Old 10-02-2016, 06:14 PM   #3
Rewards Points: 144
It definitely goes on top of or outside the bushing. This service bulletin shows that.
http://www.bosch-climate.us/files/20...lacing_eco.pdf
For what ever reason I can't get the bushing pushed in far enough . It does not appear to be keyed in anyway.
Old 10-02-2016, 07:22 PM   #4
Rewards Points: 3,216
Welcome to the forum spinnaker.
The link you posted for service bullentin doesn't match the picture in your manual. This link to the service bullentin matches picture in your manual;
http://www.bosch-climate.us/files/20...let_filter.pdf
However, I agree with you, looking at the diagram, it looks pretty straight forward. I really don't know of any tricks (perhaps you are not lining in up correctly), looks like the retainer clip goes right on top like you said. If you still can't get it figured out give bosch a call in the morning first thing and ask them. Don't void your warantee by forcing anything.
Perhaps someone here has worked around one of these and knows. Please standby. Thank you.
jmon is offline   Reply With Quote
Tankless water heater to pre-heat incoming water matthet Plumbing 35 01-06-2017 12:39 AM
Bosch 1600H Lp tankless water heater Dixie2 Plumbing 14 10-11-2012 06:58 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
