Refridgerator Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2016, 06:51 PM   #1
Rewards Points: 93
Refridgerator line
Hello,
So I am in the midst of installing the water line to the fridge. I already have a tee into the copper 1/2 line with a 1/2 ball valve installed. Is there any fitting/connection/reducer that will get the copper 1/2 out of the ball valve reduced to the 1/4 copper line? I know that there are other valves with 1/4 outputs but I already had the 1/2 ball valve so figured I'd use it .
Thanks!
bfan781 is offline   Reply With Quote
Old 01-01-2016, 07:10 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
http://s3.supplyhouse.com/images/pro.../c74-064-2.jpg
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 01-01-2016, 07:50 PM   #3
Rewards Points: 93
That's exactly what I'm looking for. So it just threads on with some Teflon tape?
Old 01-01-2016, 08:22 PM   #4
griz's Avatar
Rewards Points: 572
get a stainless steel flex line.
griz is offline   Reply With Quote
Old 01-02-2016, 04:10 PM   #5
Rewards Points: 114
If you have an IPS ball valve then yes. If you have a sweat ball valve, they make compression x sweat version of that fitting. You're going to have to make at least one solder connection if it's a sweat valve with nothing soldered into the downstream end.
2x_Tom is offline   Reply With Quote
