Refilling Trench For Sewer Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-03-2016, 07:21 PM   #1
Rewards Points: 291
Refilling trench for sewer line
I've dug up a section of sewer line that has root intrusion to have access for relining and I want to know the recommended material to fill around the pipe to reduce the chance of future root intrusion. The pipe is 4" clay and I notice the joints where two are connected has a cement material and this is the vulnerable joint where roots enter the pipe. Is it a bad idea pouring salt around the joints? Any tricks of the trade before I refill the trench?
seephor is offline   Reply With Quote
Old 04-03-2016, 08:05 PM   #2
Rewards Points: 1,856
Re: Refilling trench for sewer line
rootx
http://www.newtechbio.com/rootxfoami...FQgoaQodQc4CeQ
Old 04-04-2016, 06:53 PM   #3
Rewards Points: 352
copper sulfate
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
Javiles (04-06-2016)
main supply line needs to be replaced - your thoughts NABRIL Plumbing 7 03-16-2014 07:42 PM
Water Dripping From Circuit Breaker Box/Frayed Service Line Magnetic Electrical 6 02-03-2014 03:50 PM
Excessive Flow Limiting Device in Natural Gas Flexible Line Perry401 Plumbing 2 11-29-2013 05:37 PM
5/8 water meter with a 1 inch servise line ????? ogoz23 Plumbing 11 02-04-2012 10:35 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
