Redirect Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2015, 09:10 AM   #1
Rewards Points: 71
Redirect sump pump
I am buying a home where the sump pump water is pumped to the backyard onto patio stones which meet the back of house. I am going to ask the sellers to redirect water somewhere else rather then on patio stones. Any suggestions to minimum distances away from house structure or where I should request water be pumped to?
Thank you
RichTibo is offline   Reply With Quote
Old 05-20-2015, 11:32 AM   #2
Rewards Points: 3,512
Could you please post a picture of the discharge area in question so we can give you better advice. Thanks.
When redirecting discharge, make sure it's a few feet away from foundation and slopes away.
Others will be along with more advice/suggestions.
jmon is online now   Reply With Quote
Old 05-20-2015, 12:25 PM   #3
Civil Engineer
Rewards Points: 5,246
If it is possible, and allowed by local codes, sump pump discharge should go to the storm drain system on the street. If that is not possible, the water needs to be pumped far enough away from the house so it drains away from the house. Sump drainage normally cannot be directed into the sanitary sewer system
Sump Pump Backup System steve-19 Plumbing 1 01-18-2013 12:15 PM
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 01:55 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
understanding the numbers on a sump pump and which one to buy ksimpson Plumbing 0 09-09-2011 07:51 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
