Recommendations For A Laundry Tub Above Deck Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2016, 09:27 PM   #1
Rewards Points: 6
Recommendations for a laundry tub above deck faucet
I need to replace the laundry tub faucet in my basement. It is above deck, similar to: Central Brass 0466
hmmm wont let me post link....
I am seeking recommendations for a high quality brass replacement.
The one in my basement is probably 50 yo.
If any mfg has laundry tub faucets with newer style cartridge valves that are easy to replace, that is a plus that I'd like to know about.
While I am price conscious, I am not adverse to paying for the quality.
The ones from HD, Lowes, etc seem to be junk.
Thanks a lot for your help
-John
three_jeeps is offline   Reply With Quote
Old 10-02-2016, 09:59 PM   #2
Rewards Points: 3,208
Re: Recommendations for a laundry tub above deck faucet
Welcome to the forum three jeeps.
I responded to your post, you should be able to post your pictures now.
jmon is online now   Reply With Quote
Old 10-02-2016, 10:42 PM   #3
Rewards Points: 1,852
https://www.wolverinebrass.com/p/502...-mountsatin-ch
Old 10-03-2016, 06:29 AM   #4
Rewards Points: 18
Originally Posted by Ghostmaker View Post
Are those available at bigbox stores or only at supply houses? Also, since they are compression stems rather than cartridges, how often do you have to replace the washers? I thought someone told me that Gerber makes a similar faucet that uses cartridges. Have you ever used those?
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 10-03-2016, 02:25 PM   #5
I've used wolverine brass back in my repair days. I think they only sell to plumbers but the policy may have changed since it has been a while. The tub shower and faucets are cartridge based. The laundry faucets do use washers but they are very heavy and high quality.
On the repair side I used to hand the customer the Delta KS and the wolverine. Wolverine usually won due to the basic weight.
Old 10-03-2016, 07:42 PM   #6
Rewards Points: 6
Originally Posted by jeffmattero76 View Post
snip
I've discovered that Gerber makes a laundry deck mount cartridge model:
https://s3.amazonaws.com/gerber-gh/5...b7a/49-530.pdf
I have no idea about Gerber quality. Cartridge valves are appealing to me for their longevity (if they are well designed & mfg).
The wolverine looks to be a good faucet, with a heavy disk, will probably outlast me.
Thanks for the responses.
J
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
Tub Faucet with Showerhead recommendations yan54188 Plumbing 15 09-12-2007 10:47 AM
