Rebuild Old Water Shutoff Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-20-2014, 04:39 PM   #1
bryanp22's Avatar
Rewards Points: 362
Rebuild old water shutoff valves
I have some old water shut offs that need seals. For the packing nut washer and the washer on the end of the valve stem are those a certain standard size? I tried looking for them at Home Depot but I didn't see anything.
bryanp22 is offline   Reply With Quote
Old 04-20-2014, 04:43 PM   #2
Rewards Points: 18,988
There is no "standard size".
Replace them with ball valves and never have them leak or fail again.
SHR Plumber (04-22-2014)
Old 04-20-2014, 04:47 PM   #3
Rewards Points: 6,546
Ace hardware ( at least the one nearest me ) is 10 times better for plumbing supplies than any box store I've been in.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
ben's plumbing (04-20-2014), TheEplumber (04-20-2014)
Old 04-20-2014, 04:52 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 286
I agree. When it comes to packing and such- Ace is the place......
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 04-20-2014, 07:01 PM   #5
bryanp22's Avatar
Rewards Points: 362
Okay will try them. They were closed today.
Old 04-22-2014, 07:00 AM   #6
Rewards Points: 3,130
Repacking valves?? My Lord, I haven't done that (or even thought about it) since I was in the Navy 40 years ago.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 04-22-2014, 10:20 PM   #7
Rewards Points: 38
Never rebuild shut-off valves! Replace with new quarter turn valves and never have to think about them again. Really.
SHR Plumber is offline   Reply With Quote
Old 04-22-2014, 10:21 PM   #8
bryanp22's Avatar
Rewards Points: 362
It's on old galvanized pipe I don't want to replace is my only concern on why I want to repack. It's shutoffs in my basement for pipe that goes to second floor. I know I will have to replace some day but I have good water pressure so that is an expense I am trying to avoid for now
Old 04-23-2014, 04:21 PM   #9
Rewards Points: 1,950
Get this http://www.ebay.com/itm/like/281312892631?lpid=82
Old 04-23-2014, 08:21 PM   #10
Rewards Points: 38
Teflon stem packing rope, new bibb washer (maybe a screw too), new faucet cap washer and a faucet reseating tool and you will be able to fix the valves. I rebuild inline stop valves all the time. I thought by "shut off valve" you were referring to under sink shut offs.
The Following User Says Thank You to SHR Plumber For This Useful Post:
MTN REMODEL LLC (04-23-2014)
Old 04-23-2014, 08:28 PM   #11
bryanp22's Avatar
Rewards Points: 362
Do the inline valves use a particular size washer you can point me to online?
Old 04-23-2014, 10:20 PM   #12
Rewards Points: 38
No standard size. Purchase a multi-size selection with screws and the teflon stem packing at any plumbing supply store.
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 08:57 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Main Water Shutoff Valve Inside leaking kentifur Plumbing 6 11-03-2011 07:16 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
