Rads Downstairs Cold - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2015, 11:13 AM   #1
Rewards Points: 4
rads downstairs cold
pumped C/H, gravity fed HW.
pump is ok (new). cleared a blockage from cold feed. but still rads downstairs remain cold. any help would be appreciated. thanks
roylufc is offline   Reply With Quote
Old 01-18-2015, 01:00 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,250
Ayuh,.... Did ya bleed the system to remove any air,..??
Old 01-18-2015, 01:12 PM   #3
Rewards Points: 4
thanks for reply, have bled it till the cows come home, i'm stumped at the moment
Old 01-18-2015, 02:54 PM   #4
Bondo's Avatar
Ayuh,.... The more ya tell Us 'bout yer system, 'n troubles, the more replies you'll get,...
What's the C/H,..??
Gravity fed,..??
Which pump mounted where,..??
Trickle of Cold Water Pioneer Bathtub Faucet egawrons Plumbing 0 10-25-2012 11:24 AM
Hot upstairs but cold downstairs Barton6435 Plumbing 2 12-20-2010 08:08 AM
Cold Air timmy k HVAC 0 12-14-2010 06:26 PM
Cold Air Return issue ra1185DIY HVAC 1 12-05-2010 03:21 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
