Radiator - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2015, 04:08 AM   #1
Rewards Points: 8
radiator
I have 5 radiators 4 of them work perfectly and one of them just gets warm but if I turn the other 4 off it goes hot, I have bled the radiator so water is coming out of it but this hasnt solved the problem, any ideas please
jay5858 is offline   Reply With Quote
Old 12-08-2015, 04:54 AM   #2
An old Tradesmen
Rewards Points: 9,504
What is the pressure on the boiler gauge, and is this rad on a higher level then the others. Was the circulator changed out, and then this started to happen?
Old 12-08-2015, 05:11 AM   #3
Rewards Points: 8
it says 1.3 bar, and all the radiators are on the same level even though they are different sizes
Old 12-08-2015, 05:20 PM   #4
An old Tradesmen
How long has it done this? Is the home very long, or short. Post brand and model number of your circulator.
Old 12-08-2015, 06:03 PM   #5
Rewards Points: 5,348
Where in the sequence is the bad radiator?
Ron
B. Franklin 1759
Old 12-09-2015, 03:51 AM   #6
Rewards Points: 8
its probably the last in the loop situated in a 12ft x 10ft living room it was installed 18 months ago its a glow worm 30cxi boiler
Old 12-09-2015, 03:59 AM   #7
An old Tradesmen
Probably not piped up right. You can probably get a way with just getting a higher rated circulator.
Old 12-09-2015, 04:12 AM   #8
Rewards Points: 8
there was a larger radiator there previously but this was changed when we had the conservatory built, the radiator has been working perfectly for 18 months up until recently
Old 12-09-2015, 04:36 AM   #9
An old Tradesmen
Check the amp draw of the circ while its running, and see if its drawing more then its FLA rating.
Could someone have turned the valve closed tightly, and then reopened it. If so, sometimes the valves don't actually reopen from being over tightened.
Is this a mono flow system, or a 2 pipe system.
problems bleeding new radiator on monoflo T system wombosi Plumbing 1 04-17-2012 06:42 AM
Repairing converted Steam to Hot Water Radiator system - HELP! JonathonT HVAC 0 09-27-2011 09:08 AM
Steam Radiator in Hot Water System whitesjtaa HVAC 4 01-11-2010 08:32 PM
Radiator Question mismos00 HVAC 17 11-02-2008 02:55 PM
Hot Water System -- Cold Radiator formarley HVAC 4 03-04-2008 07:09 AM
