Quick Septic Answer - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree8Likes
  • 1 Post By rjniles
  • 1 Post By mark sr
  • 1 Post By Nealtw
  • 1 Post By JBoot
  • 1 Post By Nealtw
  • 3 Post By chandler48
Old 05-30-2019, 03:26 PM   #1
Rewards Points: 866
Quick septic answer
A person is renting in a building thats on septic. They said some units are vacant an they say theres a bad odor from the septic.
How can an owner fix this?
Does a septic serving multi units need to have water from all units going into septic?
Startingover is online now   Reply With Quote
Old 05-30-2019, 03:33 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 638
Re: Quick septic answer
In vacant units sink traps and toilet bowls can dry up and allow sewer gas to enter building.
Sent from my RCT6213W22 using Tapatalk
Startingover likes this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 05-30-2019, 03:46 PM   #3
Rewards Points: 866
So would easiest solution for LL who isnít around ......if units are unlikely to be rented.....would that be to pull toilets an sinks an cap them off?
Old 05-30-2019, 03:53 PM   #4
retired painter
Rewards Points: 1,736
If the water is on in those units it would be easier to flush the commode and run a little water in the sinks every so often.
Johnny_inFL likes this.
mark sr is offline   Reply With Quote
Old 05-30-2019, 03:55 PM   #5
retired framer
Rewards Points: 20,276
He should have some on top them up every 2 weeks. Including the washer drain.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 05-30-2019, 04:03 PM   #6
Rewards Points: 866
Seems like Absentee Landlords arenít uncommon around here.
Maybe investment properties or tax write offs. Owners donít care
Old 05-30-2019, 04:10 PM   #7
retired framer
Then phone the local health department. Make sure you have the LL number and address handy to give them.
Old 05-30-2019, 04:14 PM   #8
Rewards Points: 152
...and don't forget to pour some water in the floor drains.
JBoot is offline   Reply With Quote
Old 05-30-2019, 04:28 PM   #9
Rewards Points: 866
Its a really small town where everyone knows or is related to someone
so this person may not want to be the one to call the Health Dept.
You guys are great
Old 05-30-2019, 04:32 PM   #10
retired framer
You guys are great
It really is a safety issue, the gas is deadly and flammable, who you gonna call
Old 05-30-2019, 06:38 PM   #11
Naildriver
chandler48's Avatar
Rewards Points: 4,232
IF the units are vacant, pouring RV Antifreeze in all traps (including washing machine stand pipes) and commodes will help. The antifreeze won't evaporate like water will and it is flushable with no adverse effects.
Startingover, lenaitch and Nealtw like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Startingover (05-30-2019)
Old 05-30-2019, 08:40 PM   #12
Rewards Points: 866
Chandler, very interesting. Iíll pass this along! Thank you.
Old 05-31-2019, 11:18 AM   #13
Maintenance / Locksmith
Rewards Points: 238
Flush toilets, run water into all drains AND floor drains. Pour about 1 ounce of mineral oil in each and it floats on the water and stops evaporation.
Dual purpose......if your stomach is upset the mineral oil will also work for you!
georgemcq is offline   Reply With Quote
Old 05-31-2019, 01:19 PM   #14
Rewards Points: 4,406
Look up stagnant water.
Stagnant smell.
ron45 is offline   Reply With Quote
