Quick Question For The Pros - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2015, 01:53 PM   #1
Rewards Points: 8
quick question for the pros
we have a Navien CR-180 tankless water heater
we had an error code 37, water leak inside the entire enclosure
took the cover off, there was a bit of water, the circuitry did not get wet
the leak is a steady trickle at the top of the "h/e connecting pipe" where it meets the "water pipe adaptor B" , probably a busted O ring, or the heater exchange might be cracked and causing the leak
cold water inlet is shut off at the moment
my question is, can we run this unit for 30 minutes with a funnel (connected to flex piping leading to a drain) , under the leak so that the wife and I can take a shower, and then turn off the unit and water supply until the tech shows up with parts on Tuesday and fixes the leak ?
please check these photo links to see what I'm talking about
thanks in advance
philips80 is offline   Reply With Quote
Old 01-24-2015, 06:50 PM   #2
Retired Moderator
Rewards Points: 7,174
Give it a try--have one of you watch the unit as you run it---will it work while the error code is displayed?
Old 01-24-2015, 08:57 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
May not be enough pressure to activate the flow switch
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Quick Wire Size Question leeave96 Electrical 5 08-22-2011 05:33 PM
Quick outlet question RodBarney Electrical 5 08-20-2011 12:06 AM
New here! Quick question. tmichelsons Building & Construction 5 06-15-2011 12:18 AM
Quick Bathroom Plug and switch Question mclemenc Electrical 5 01-30-2011 10:02 PM
Quick Question Need to Pickup Parts Today kuteazn1 HVAC 5 12-21-2010 02:52 PM
