Quick Fix For Leaking PVC.....?? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
  • 1 Post By Joeycarnuba
  • 1 Post By MTN REMODEL LLC
  • 1 Post By bensplumbing
  • 2 Post By KC_Jones
  • 1 Post By Cedrus
Old 05-08-2017, 09:04 AM   #1
Rewards Points: 704
Quick fix for leaking PVC.....??
My one inch PVC glued fitting has a pin hole leak. Maybe i cup/day.
I read somewhere that if I shut off the water and drain the line.....and have some glue (or primer) handy.....at some point I can apply some glue or primer.... and it will be sucked down into the leak and possibly be fixed.
Is this possible ? This would be an easy fix as there are a variety of glued, threaded fittings, clamps on flex line, etc.
Thanks...and what exactly is the proper procedure to do this ?
Cedrus is online now   Reply With Quote
Old 05-08-2017, 09:56 AM   #2
Rewards Points: 122
Re: Quick fix for leaking PVC.....??
The proper way to fix the leak is to cut out the fitting and reinstall a new fitting.
de-nagorg likes this.
Joeycarnuba is offline   Reply With Quote
Old 05-08-2017, 10:02 AM   #3
JUSTA MEMBER
Rewards Points: 3,790
As Joey said, the proper way is replace the fitting.
Now for an easier way.
Get a can of FLEX SEAL spray, shut off the water, spray the entire fitting, wait an hour ( not necessary), and turn on the water.
It'll be stopped.
I used to think that this stuff was just a TV gimmick, until I tried it.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
mark_kershner (05-09-2017)
Old 05-08-2017, 01:15 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,834
It'll be stopped.
ED
Ed.... REALLY.... On a supply line.....what kind of pressure in your line...???
Mike Milam likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-08-2017, 01:45 PM   #5
ZTMAN's Avatar
Rewards Points: 624
I agree. Maybe patch a drain line, but not a supply line. Not worth the potential consequences
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
bensplumbing (05-08-2017)
Old 05-08-2017, 03:36 PM   #6
JUSTA MEMBER
OP did say that maybe a cupful is al it leaks per day.
Therefore the pressure is greatly reduced or not much, so that stuff should seal it, Did you both overlook the fact that I did say first that the way was to replace the fitting?
ED
Old 05-08-2017, 03:39 PM   #7
ZTMAN's Avatar
Rewards Points: 624
I did not over look your initial advice. I think you agree the proper way to fix it is to replace the fitting.
In an emergency I would use the flex seal as a temp repair
de-nagorg (05-08-2017)
Old 05-08-2017, 06:35 PM   #8
Rewards Points: 38
There is only one way the right way....replace the fitting...end of story....
bensplumbing is offline   Reply With Quote
Old 05-08-2017, 06:54 PM   #9
Rewards Points: 704
Thanks for the replies.....I found a blurb where someone shut off the water and used a shop vac to create suction and applied primer and then glue. Think I will try that first.
Secondly, if that no workee....I'll try either A&B epoxy or Pool Patch.
Old 05-08-2017, 07:08 PM   #10
Property Mgt/Maint
Rewards Points: 8,202
Anything to avoid a real plumbing repair. How about a shark bite, no glue required.
I did see a FlexSeal commercial last night where they introduced a new tape patch. They repeatedly patched gushing leaks in pools, tanks, and pipes. It worked on TV, but I would still be hesitant to try it on a pressurized line.
I am not endorsing this product for this application
https://www.flextapeoffer.com/FLXTP/...169&otsid=3758
Yodaman is online now   Reply With Quote
Old 05-09-2017, 08:21 AM   #11
Rewards Points: 704
Well.....this is the DO IT YOURSELF forum. You might remember that old TV ad about Asprin or Advil or something: "Mother...PLEASE !....I'd rather do it MYSELF"
Old 05-09-2017, 11:03 AM   #12
Rewards Points: 454
You do understand do it yourself doesn't mean do it wrong don't you? You ask for advice how to fix it. The way to fix it is to cut it apart and redo the piping properly (which obviously wasn't done the first time).
You will spend more time and effort trying to fix it incorrectly than it will take to fix it properly. If you are one that enjoys turning a simple repair into a life long conquest by all means keep doing what you are doing.
bob22 and Mike Milam like this.
KC_Jones is offline   Reply With Quote
The Following User Says Thank You to KC_Jones For This Useful Post:
Ghostmaker (05-09-2017)
Old 05-09-2017, 02:28 PM   #13
Rewards Points: 704
Hi KC and others...a closer look revealed I could not remove the bibb via threaded riser; I had to cut it out. I see two tiny cracks in the riser and in the elbow. So...everyone is correct: I won't try and use the shop vac and primer/glue fix.
I'll buy needed fittings and try and use more threaded fittings...less glued parts.
I am retired and do enjoy trying new/interesting/stupid things...cuz I have lots of time on my hands.
Yodaman likes this.
Old 05-09-2017, 03:20 PM   #14
JUSTA MEMBER
Quoted I am retired and do enjoy trying new/interesting/stupid things...cuz I have lots of time on my hands.
Yeah same here, but that don't mean I'm going to try Bungee Jumping, or Zip line.
My mama did not raise a fool.
ED
How quick is quick set cement/mortar? miamicuse Building & Construction 2 08-02-2015 05:30 PM
Quick wiring question.... TALDE Electrical 23 02-15-2014 05:10 PM
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
Quick Release Fence Post JasonCA Building & Construction 8 02-14-2012 09:15 AM
Quick Step perspective flooring dawnparkin545 Flooring 1 06-25-2011 11:51 AM
