Questions About Water Heater Anode Rods - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2016, 06:48 PM   #1
Rewards Points: 682
Questions about water heater anode rods
I have some heaters with little clearance overhead. It would be hard to remove the anode rod. My questions are:
1) How long is a typical anode rod?
2) How would you get the old one out if there is little clearance (2' or less) over the water heater?
3) What type of metal in an anode is preferable?
4) Are those linked flexible anode rods good? (I fear they will fall apart at the links)
4) Is there a standard sized socket for removing anode rods?
darsunt is offline   Reply With Quote
Old 02-02-2016, 07:33 PM   #2
Rewards Points: 3,234
depends on water heater. about 2-3 foot avg. I've seem them longer.
you could cut it and use flexible or telescopic one to replace it.
3) What type of metal in an anode is preferable? most are magnesium or aluminum. Preferred is magnesium, imo. Really depends on type of water you have.
4) Are those linked flexible anode rods good? (I fear they will fall apart at the links) I don't have any personal experience with them. If space is limited you may not have a choice unless you want to drain, and disconnect/tilt water heater to change it out. You can google customer satisfaction and read up on it.
1 1-16, 1/2 inch drive with long breaker bar using extra leverage. Best to use impact wrench if possible. Easy peasey. The above are just my personal opinons as a diy homeowner.
jmon is offline   Reply With Quote
Old 02-02-2016, 07:44 PM   #3
Rewards Points: 18,808
There is no "typical" length or socket size.
Depends on the size of the heater.
What makes you think it need to be changed?
Old 02-03-2016, 10:44 AM   #4
Rewards Points: 682
The heaters are old, 10 years +. How often should they be changed? I've heard if you keep up with fresh rods your heater lasts forever.
Old 02-03-2016, 02:05 PM   #5
WhatRnsdownhill's Avatar
Rewards Points: 2,220
not really, but how many times have you flushed all the junk out of the bottoms? if not on a regular basis like 6 month intervals, the stuff bakes on into a solid mass..then the bottom plate of the heater super heats and warps causing leaks...if gas or oil fired..electric not so much..
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
ben's plumbing (02-03-2016)
Old 02-03-2016, 02:26 PM   #6
Any water heater older then a max of 15 years (many are less) is living on borrowed time.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
ben's plumbing (02-03-2016), WhatRnsdownhill (02-03-2016)
Old 02-03-2016, 02:29 PM   #7
Rewards Points: 5,682
If you decide to go forward with the anode replacement let me suggest a 6 point socket rather than a 12 point. Also an impact wrench isn't all that common in the usual house hold tool bag and if you don't have one a 2x4 about 3 ft. long makes a hellofah impactor if there is room to swing it. In certain situations I usually tether the wrench to keep it from possibly impacting body parts and or other valuables.
I usually charge for these kinds of ideas but this first one is free.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Chris130 (02-03-2016)
Old 02-03-2016, 04:29 PM   #8
Rewards Points: 1,600
anode are often almost the same lenght that the tanks is, mine is over 4 feet long for a 60 gal unit. i personally replaced it with an electrical titanium anode that is very small.
carmusic is offline   Reply With Quote
Shopping for New Electric Water Heater Lots of Questions LeakyHawaiiRoof Plumbing 3 11-02-2014 01:18 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Sign of deteriorating water heater anode? Frank O Plumbing 18 02-28-2010 12:52 PM
Bradford White water heater adpanko Plumbing 0 02-10-2010 03:33 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
