Question: New Toilet Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2016, 01:02 PM   #1
Rewards Points: 50
Question: new toilet drain
probably dumb question...but wondering how I open up this toilet drain when installing the toilet.
1. new bathroom addition.
2. plumber installed new pipes, then had foundation laid. getting ready to tile floor
3. so the toilet drain in this pic... do I cut the white plastic out from the top to create the opening?? Or do I saw off the very top of the black pipe to create the opening. Or is that white part just a cap that I can pull out, haven't looked that deep.
thanks for the help!
Question: new toilet drain-img_34062.jpg
jcrizzy is offline   Reply With Quote
Old 04-09-2016, 01:24 PM   #2
Rewards Points: 50
Re: Question: new toilet drain
I think I have to cut flush with the floor, after looking more.
but should I cut now flush with concrete.
or wait after tiling...then cut flush with finish tile. sounds better I think (?)
the inside of the pipe is 3 3/4 (guess that's a 4" drain). and right now it sticks up 1" over the concrete.
Old 04-09-2016, 05:25 PM   #3
Rewards Points: 310
You can cut flush then get flange that fits....4" it looks like
PandJ is offline   Reply With Quote
Old 04-12-2016, 05:51 PM   #4
Rewards Points: 114
Buy the correct toilet flange, cut the pipe so that when you glue down the flange to the pipe it sits on the concrete. Make sure the tee bolt slots are set at 12" from finished wall before gluing it
Check out all of my home improvement projects at http://www.homerenovationsandtools.com
Chrisathome is offline   Reply With Quote
Old 04-13-2016, 10:21 AM   #5
SHEPLMBR's Avatar
Rewards Points: 178
SHEPLMBR is offline   Reply With Quote
Old 04-14-2016, 11:23 AM   #6
Rewards Points: 198
When he says 12" from the wall he means 12" more or less at each closet bolt opening. This is so the toilet tank is parallel to the wall. There is nothing worse than a crooked toilet...very sloppy and unprofessional.
srloren is offline   Reply With Quote
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 12:18 PM
Moving my Toilet Drain and Installing a Shower Drain Hahny Plumbing 3 04-13-2011 11:22 AM
Toilet wont drain chazlew Plumbing 11 02-27-2011 10:08 PM
Trench Drain Question Branden Plumbing 6 05-25-2010 10:02 AM
Toilet question ssteel Plumbing 11 12-12-2009 09:38 AM
