Question For Licensed Plumber - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
Old 02-19-2017, 03:09 PM   #16
hkstroud's Avatar
Rewards Points: 6,694
Re: Question for Licensed Plumber
I wanted to know if it's possible to flush a few gallons from the bottom of the water heater through a garden hose WITHOUT turning off the cold water inbound pressure?
No.
You must of course turn off the water coming into the house before you open up that line.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 02-19-2017, 03:29 PM   #17
Solidify's Avatar
Rewards Points: 834
Originally Posted by hkstroud View Post
When you see the term "some experts" you should stop reading. What you are reading is just something that someone Googled and is trying to get an article published.
Remember people write articles to make money. They only make money if they can get it published. They will will say anything to get it published.
No one is ever able to find those "some experts".
Good point.
CAA (which is like AAA for Canadians) posted that. And then they sort of contradict themselves by providing flushing instructions: https://www.caaquebec.com/en/at-home...-water-heater/
I just don't see what kind of vested interested CAA would have in not having us flush our heaters; they're not the owners of the water heater companies.
Solidify is offline   Reply With Quote
Old 02-19-2017, 03:34 PM   #18
Solidify's Avatar
Rewards Points: 834
No.
Done.
Tihs was the first time flushing (or doing any maintenance work)on this 60 gallon electric water heater that was installed in 2004. The first 30 seconds of water exiting the garden hose (not even) were definitely brown, but then the rest was crystal. I closed the drain valve, turned on the cold supply to give the insides a good ruffle and then closed the cold supply and repeated the drain but there was only clear water now. Great!
I would have changed the anode rod too, or atleast got a look at it but there's just no ceiling clearance to do so.
Oh well, definitely got my money's worth with this heater. No rust anywhere on it.
jmon likes this.
Just a quick+easy question to pest control workers and/or owners...pls read..... jkls Pest Control 2 10-09-2012 10:53 PM
Venting over the range convection oven question johncle6023 HVAC 4 08-31-2012 08:30 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 07:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 01:14 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
