Question About Rough In Plumbing That Was Done In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2016, 11:50 AM   #1
Question about rough in plumbing that was done in basement
http://imgur.com/a/Jv2lD
I have probably a pretty basic question. But here is a picture of how the plumbing is rough'd in in my 3 year old house in the basement. This is where the tub/shower is supposed to go.
Am I correct that this Black cover where there is an opening in foundation is for the shower drain? There is no drain pipe in the hole (that I could see... or do I need to dig down?).
The Drain pipes & vents I plan to frame so they are within the wall. I assume this is the norm?
Sorry for what is probably a simple question, just want to make sure I set it up correctly when I frame so there is room for everything.
Thank you.
natepuppy11 is offline   Reply With Quote
Old 07-12-2016, 02:41 PM   #2
Rewards Points: 767
Re: Question about rough in plumbing that was done in basement
Yes you need to dog down. They may have just stopped the pipe or it may have a trap on it. It would make more sense to leave a bald end and add trap where it is needed.
ct18 is offline   Reply With Quote
Very noob question about rough opening on door sonnaps Building & Construction 44 09-08-2015 07:28 PM
Question about Plumbing Basement bathroom with PEX dgreen Plumbing 5 03-08-2012 03:28 PM
Basement shower plumbing question. medicmike Plumbing 5 01-28-2012 04:40 PM
Plumbing in Basement osajia Plumbing 7 12-08-2010 12:00 PM
Basement Rough in PSULion55 Plumbing 1 02-06-2010 12:44 AM
