Question About Re-Routing Vent Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2016, 07:23 PM   #1
Rewards Points: 599
Question about Re-Routing Vent Pipe
We are contemplating a little bathroom remodel including inset medicine cabinets. When I last did any work in this bath about six years ago, I recall that at least one of the spots for the recessed cabinets has a vent pipe running through it vertically. Fortunately, it is a non load bearing wall, so I have pretty much a free hand.
In general, is it permissible to re-route the pipe around the cabinet (it probably would take four nineties to do so...). If not, what problem would that type of re routing generate?
Curmudgeon10 is offline   Reply With Quote
Old 02-26-2016, 10:20 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 166
It will be fine. As general rule, vents should not be run horizontal until 6" above the flood rim of the fixture- 42" is the rule of thumb
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (02-27-2016), Curmudgeon10 (02-28-2016), dd57chevy (02-28-2016)
Old 02-28-2016, 04:35 AM   #3
Rewards Points: 599
Thanks!
Vent Pipe Question Litzner Plumbing 3 10-09-2012 11:41 AM
Distance from vent pipe to clean out? toddmanqa Plumbing 2 03-24-2012 01:41 PM
Double wall gas vent pipe? Cubey HVAC 19 10-22-2011 11:28 PM
Shop heater, gas pipe in contact with vent Richo HVAC 15 02-05-2011 10:28 PM
