Question About Installing An Outdoor Hose Bib - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By chandler48
Old 07-26-2017, 06:06 PM   #1
Rewards Points: 18
Question about installing an outdoor hose bib
I am installing an exterior hose bib. I have two questions.
My first question has to do with if there are any codes/requirements about its location. I am running the pipe from a bathroom. On the exterior wall of the bathroom is the gas line and gas meter. Does the bib need to be a certain distance from the meter/gas line?
My second question has to do about what pipe I can splice the outdoor line from. Unfortunately the bathroom sink is blocked by the exterior wall to my sun room. Can I run it from the toilet pipes?
I've attached a picture to better illustrate. The window is right above the toilet. The sink is to the left of the meter and within the sun room.
12heather is offline   Reply With Quote
Old 07-26-2017, 06:58 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 900
Re: Question about installing an outdoor hose bib
The gas meter is not an code issue. Yes you can use the toilet supply.
Sent from my RCT6203W46 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 07-26-2017, 07:03 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,724
If your crawlspace is accessible, I would tap into a full 1/2" or 3/4" line. Don't use the toilet's small supply tube as a source. Use the pipe coming ahead of the stop valve, which would probably be 1/2".
joecaption likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 07-26-2017, 07:09 PM   #4
Rewards Points: 18,990
If you can find a 3/4" main supply line, it will have twice the flow of a 1/2" line.
Old 07-27-2017, 10:30 AM   #5
Rewards Points: 80
Around here, you won't be in a gas code violation with the gas line and meter. Make sure that you seal the hole nicely.
Electrical would be a different story.
Cheers!
supers05 is offline   Reply With Quote
Having blown in insulation added to my attic. Question about installing gable vent f Finch1985 Insulation 17 04-04-2015 06:32 PM
Question installing cold trim kxweil38 Carpentry 11 03-03-2015 07:12 PM
question about installing beadboard wainscoting? jay137 Remodeling 1 02-06-2015 02:13 PM
Question about installing closet wire shelving WayneK Carpentry 15 11-16-2014 11:19 PM
Question on installing pergo stair nose amaruenterprise Carpentry 11 10-11-2009 05:21 PM
