Question About Bathroom Demo - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-02-2017, 09:09 PM   #1
Rewards Points: 191
Question about Bathroom Demo
Good Evening folks,
I am about 80% done with my bathroom demo. currently working on one last wall which is cement board (wish me luck) and i also have an old cast iron tub that has a porcelain outer layer it appears.
so my two big questions:
-how do i detach the drain and the overflow from the tub? i looked into the drain it looks to just be copper doing a 90. should i just try to cut around it or do i go in basement and cut the copper?
- best way to smash the tub? from what i see on youtube my trusty sledge is the way to go
thanks for input
rygar is offline   Reply With Quote
Old 07-03-2017, 05:04 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,652
Re: Question about Bathroom Demo
First, undo the overflow from within the tub. It is a straight pipe down to the drain which forms a tee. Undo the drain from within the tub with a drain removal tool or a pair of pliers. At that point the tub will be free from the plumbing. If you decide to demo the tub, be sure to wear safety goggles and hefty gloves with long sleeve shirt. Those shards are like little knives and will cut you.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Tapping CPVC supply lines for new bathroom - question NEW-B Plumbing 0 05-12-2011 09:20 AM
Help! Bathroom Question ryuki Painting 5 02-02-2011 12:17 AM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Question about installing tile in my downstairs bathroom UpComingBuilder Flooring 1 05-21-2009 07:17 AM
