PVC Test Tee As Horizontal Cleanout Or Vent Tee In NYS? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2016, 01:18 AM   #1
Rewards Points: 331
Question
PVC test tee as horizontal cleanout or vent tee in NYS?
Can I use a 4" test tee horizontally as a cleanout or for venting in New York State? I've read NYS plumbing code and I can't find that it's specifically forbidden, but I don't know where I should look really.
They sell a cleanout tee at home depot that is terrible, it has jagged edges on the inside of it where the 3 pieces of pipe that it's made from come together and I'd guess that could obstruct the flow of the waste.
Another thing I'm wondering, I notice when I screw a male threaded fitting onto the test tee that it doesn't go all the way in. Looking closely at the fitting I can see that it's slightly tapered, so I wonder if maybe it's not designed to go all the way in. How much force should be used to turn it before stopping? Is that in code somewhere? Thanks
Deck is offline   Reply With Quote
Old 06-01-2016, 04:45 PM   #2
Rewards Points: 1,942
Re: PVC test tee as horizontal cleanout or vent tee in NYS?
How deep will it be buried?
Old 06-01-2016, 05:05 PM   #3
Rewards Points: 331
It's above ground, it will be somewhere on the red section in this post.
Old 06-21-2016, 02:06 AM   #4
Rewards Points: 331
Does anyone know the answer? I haven't been able to figure it out and I'm getting ready to cement some pieces this week.
Old 06-21-2016, 04:06 PM   #5
Not sure how to answer you. Your code looks like IPC. Could you draw an isometric of your intentions.
Old 06-21-2016, 09:26 PM   #6
Rewards Points: 331
I don't know what that means but you can see a picture in this post. Basically what I want to do is use a test tee horizontally on the lower horizontal run of PVC so that I can open it up and check once in a while to see if it's starting to slow. We have a tree root problem and when the water flow starts to slow I can tell the roots are back.
I re-read the IPC but I can't see where it's prohibited. I can't find a section of allowed fittings in allowed configurations, or whatever it might be called.
Old 06-21-2016, 10:40 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 258
I can't think of a reason not to allow it. Especially with the opening on top. You could always use a wye with a clean out adapter glued in the branch.
My code would require a clean out at the end of that line too.
The Following User Says Thank You to TheEplumber For This Useful Post:
Deck (06-21-2016)
Old 09-20-2016, 11:19 PM   #8
Rewards Points: 331
I ended up using the test tee. It's helpful because I can unscrew it and look in the pipe with an auto shop mirror and see if it's clean. A picture of the installation is the last picture in this post.
plumbing vent boilermaker27 Plumbing 5 09-26-2013 07:37 PM
Horizontal dry vent? Stephen S. Plumbing 7 06-14-2012 09:48 AM
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 07:55 PM
Best way to vent garage and attic mikeinaz Roofing/Siding 8 03-22-2012 09:48 AM
New furnace, new placement, vent pipe horizontal run length allowed? WillK HVAC 1 01-23-2011 07:16 AM
