Is This PVC Pipe A Sewer Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2016, 09:49 PM   #1
Rewards Points: 44
Is this PVC pipe a sewer drain?
I have a 2015 built home in Minnesota, this picture is from my basement. There is a rough in for a bathroom and a drain in the mechanical room that is pretty much clear across from where this picture is.
2 floors above on this side of the house there is a guest bedroom. But I am unsure exactly what this pipe is. I am hoping it is an additional sewer drain because it appears to have a cleanout.
Any ideas?
mattylance is offline   Reply With Quote
Old 09-23-2016, 10:29 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,584
Re: Is this PVC pipe a sewer drain?
I don't know about being an "additional drain" but it sure looks like a drain or maybe venting for the drain.
Old 09-24-2016, 05:05 PM   #3
Rewards Points: 1,852
run the water in the guest bathroom you should hear it pouring down that stack if that is what it is. It might also be a radon vent that some idiot put a clean out on.
Ghostmaker is online now   Reply With Quote
ac condensation drain pipe sweating in wall buzhazzard HVAC 5 08-09-2015 11:39 AM
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 02:07 PM
Zep Drain Care for larger drains? Ultrarunner2017 Plumbing 13 01-10-2013 09:51 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
