PVC Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2017, 08:33 PM   #1
Rewards Points: 438
PVC noise
Hello,
I have PVC pipes in the attic - I believe it's HVAC air intake and exhaust. I noticed that some are directly in contact with attic wood frame/joist or against a 2x4. At times I hear loud pop especially with heater running. Could the PVC rubbing against wood frame cause this? Or perhaps touching roof deck?
Please see pict below:
One more pict showing the J clamps and how the pipes are touching wood frame.
sbkim is offline   Reply With Quote
Old 04-24-2017, 08:51 PM   #2
Plumber
TheEplumber's Avatar
Re: PVC noise
It's possible. The two that parallel each other are for your furnace or water heater (direct vent appliance) One of those two pipes is the exhaust. It may be heating and expanding.
The other line is a plumbing vent. It should not do any expanding in a normal scenario.
Old 04-24-2017, 09:01 PM   #3
Rewards Points: 438
Re: PVC noise
Thank you Eplumber. You are correct, it's my from my HVAC in the attic furnace room. Is it advisable to hang these pipes from the roof as opposed to securing on to the attic floor frame?
I presume the 2 other PVC are just vents and shouldn't be moving around much? There is no noise when I use water so I presume they are not the culprit.
Old 04-24-2017, 09:58 PM   #4
Plumber
Re: PVC noise
Without getting in your attic and looking around- I'd say your popping sound is coming from those straps on the horizontal lines (4x header beam). Be sure they have some play in them as they might be binding the pipe- Then the pipe pops free due to lateral expansion pressure
Old 04-25-2017, 06:28 AM   #5
Rewards Points: 438
Re: PVC noise
Just to clarify, are you referring to those grey plastic straps holding down the intake/exhaust pipes?
I believe you they should be loose (ie some play?) I believe they are secured with 2x4 underneath, should i remove this and put rubber or pipe insulation material?
I've read some posts indicating that I should put petroleum jelly to make the pipe slippery against the hanger.
Thanks again
Old 04-25-2017, 07:00 AM   #6
Plumber
Re: PVC noise
Thanks again
1. yes
2. if you want- don't know if it will help
3.petroleum jelly sounds like a lame idea IMO. Never seen or heard of it being done
Rattling Noise from Roof when windy drgillian Roofing/Siding 6 10-17-2018 07:35 AM
Water system noise in house, help wanted lkustb Plumbing 3 09-01-2015 09:18 AM
Condenser fan noise and then blade breaks. whotheguy HVAC 11 09-30-2013 07:59 PM
can you help me with this really odd noise? tuffluck Electrical 15 01-10-2011 05:35 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
