PVC To ABS In A Pressurized Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2015, 07:45 PM   #1
Rewards Points: 52
PVC to ABS in a pressurized line?
What's the best way of going from PVC to ABS on the waste line from a sewage pump?
All the piping and fittings for the pump, check valve and ball valve are in PVC, but all the rest of the pipe in my house is ABS.
I live in Ontario Canada where as far as I know, transition cement is okay, but I've read that its not in many other places which leaves me questioning if I want to go there.
Fernco banded couplings seem like an option, but have a maximum pressure rating of 4.3PSI....is this enough for my application?
Alternatively, I'm not sure if male/female threaded fittings can be used to make this transition?
Any thoughts?
Onagoth is offline   Reply With Quote
Old 06-18-2015, 08:09 PM   #2
Rewards Points: 3,432
Obviously you done some research and appear to be on the right track.
I Don't know about Canadian code. Oatey makes an abs to pvc transition cement. Don't know if that's a violation of code or not. I like using the proper transition coupling as you have mentioned. Just a thought.
Please wait for the plumbers to respond, they will know for sure. Thanks.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
tylernt (06-19-2015)
Old 06-18-2015, 08:27 PM   #3
Rewards Points: 1,932
Use a all rubber fernco coupling.
Old 06-18-2015, 10:57 PM   #4
Plumber
TheEplumber's Avatar
Locally we use transition glue or "fernco" couplings. I have seen the pipe separate from ferncos though but haven't seen glue joints separate- but the glue is not approved every where. You can buy the check valve with the rubber fernco connectors built into them too
Old 06-19-2015, 05:34 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Male adapter in 1 material, female adapter in the other.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Ghostmaker (06-19-2015)
Old 06-19-2015, 10:33 AM   #6
Special User
Rewards Points: 1,230
I think you will be fine with a banded coupling. As long as there is something else that's vented and draining in to the system by gravity, then water will simply back up that drain rather than build up any appreciable pressure.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 10:51 AM
Adding a second line to existing septic line Eddietan Plumbing 3 05-10-2012 09:27 AM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-04-2012 11:07 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
