Puzzling Water Temp Change - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2016, 04:20 PM   #1
Rewards Points: 1,128
Puzzling water temp change
Ok so I have two boilers and two hot water heaters. Our hot water heater is about 20 yrs old and my tenants about 28 years old. Our water was only getting warm with the setting between hot and very hot. My tenants has been set at warm and was always getting extremely hot.
Well I changed my water heater and now my water is very hot with it set at hot but now my tenants water is like warm. Any idea why this happened? Guess I'm gonna move my tenants setting to hot and see what happens. Thanks
Mstrlucky74 is offline   Reply With Quote
Old 02-16-2016, 06:17 PM   #2
Rewards Points: 3,282
1. The cold water inlet dip tube may have fallen off at that moment after whichincoming cold water commingles quickly with the exiting hot water.
2. When the water is suspected of being warm, turn the dial up a little and then turn it back to where it was. If the heater kicks on and then stays on for more than ten minutes then the controller and thermostat assembly needs replacing.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 02-16-2016, 06:35 PM   #3
Much appreciated ..will try!
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
