Push Pull Water Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2019, 01:47 PM   #1
Rewards Points: 18
Push pull water valves
My home was built in 2005-2006 and push-pull water SOVs (Flow Tite?) were installed throughout. Given all the “bad” I’ve heard about these guys, i.e. their failure rate, and assuming cost is not an issue, is it worth the trouble to replace these valves? And, if so, what is best replacement? Compression fittings or “Shark-bite” style?
jgt1943 is offline   Reply With Quote
Old 05-14-2019, 10:48 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 890
Re: Push pull water valves
Yes, they should be replaced. I install only compression but the sharkbite type connections are fine.
Also consider replacing the supply lines with braided flex
Old 05-15-2019, 09:55 AM   #3
Rewards Points: 1,784
I recently had to replace a push-pull (2002 house) that started leaking after I installed a bidet toilet seat for my wife. Sharkbite worked just fine. If it wasn't leaking I wouldn't have bothered replacing it, though.
huesmann is offline   Reply With Quote
The Following User Says Thank You to huesmann For This Useful Post:
jgt1943 (05-15-2019)
Old 05-15-2019, 04:51 PM   #4
Rewards Points: 18
Thanks , replacement seems the wise choice; I've just always had a reluctance to replace something that is still working fine, at least as of this afternoon.
And this leads to another consideration: what is the typical failure mode for these Push/Pull valves?..do they gradually being leaking as the O-ring degrades or is it more sudden, as in instant flood? Further comments on this concern will be appreciated. Thanks.
Old 05-17-2019, 11:01 AM   #5
I'm not sure, but I think the one I replaced started leaking from the swage at the end of the hose that was integrated with it. Just a few dribbles, but over time they added up, and I didn't wanna risk the hardwood floor in the P/R getting damaged.
My hot water recirculation system is a disaster Michael Neill Plumbing 29 08-30-2019 07:15 PM
Black smelly water Gradydane Plumbing 3 11-30-2018 09:42 PM
Whirlpool Energy Saver Water Heater Problem Thurman Electrical 53 10-30-2018 12:08 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
