Punctured Floor Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2015, 03:11 PM   #1
Rewards Points: 2
Punctured floor drain
Going thru inspection, inspector found floor drain pipe has been punctured to relieve hydrostatic pressure under floor slab. This does not comply with sewer district and county regulations to keep storm/sewer water separate. Is there something we can do ourselves to repair this?
rachbrew is offline   Reply With Quote
Old 06-27-2015, 03:41 PM   #2
Rewards Points: 3,418
Fix pipe and maybe install a sump pump and have it drain outside to keep ground/storm water seperate from regular sewer. Just a thought.
Best to ask the inspector he should know for sure.
Others will be along with more advice/suggestions.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
rachbrew (06-27-2015)
Old 06-27-2015, 04:54 PM   #3
Rewards Points: 1,926
You break up concrete remove broken trap and replace.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 06-27-2015, 05:37 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 240
I bet if you do these 2 things I bet you're problem will be solved
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 06-27-2015, 05:41 PM   #5
Rewards Points: 582
yep this is the proper way....not some pacth work that will fail in the future
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 06-27-2015, 07:57 PM   #6
Rewards Points: 2
Thank you for the responses! The largest part of the confusion was why this was done when we have a sump pump that works! So once we got the drain cover off we realized the Condensation Unit drain line was plumbed into the floor drain. Thank goodness we didn't have to rip up concrete! And that we didn't seal off that line!
The Following 2 Users Say Thank You to rachbrew For This Useful Post:
jmon (06-27-2015), oh'mike (06-27-2015)
Punctured neutral wire, repairable? word2yamutha Electrical 18 08-04-2014 08:08 AM
punctured gas line canadaclub HVAC 10 05-11-2014 05:37 PM
Punctured central air suction line bigd191406 HVAC 2 05-09-2010 11:49 AM
