Pumping Sewage Up Hill ( Way Up!) - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2016, 01:45 PM   #1
Rewards Points: 2
pumping sewage up hill ( way up!)
Hi All, I am in the process of planning on building a cabin on a rocky riverfront, mountain location where digging down a septic field will be impossible so I am investigating the idea of pumping sewage up. I'm talking hundreds of feet. Any comments , ideas??
hmungus is offline   Reply With Quote
Old 04-06-2016, 02:26 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,690
Re: pumping sewage up hill ( way up!)
Every foot of rise equals about .5 psi pressure needed. So 200 feet up requires about 100psi at the bottom just to make it to the top. You may need one or pumping stations along the way to make it to the top.
The Following User Says Thank You to joed For This Useful Post:
dd57chevy (04-06-2016)
Old 04-06-2016, 07:57 PM   #3
Rewards Points: 1,866
A sanitary engineer might be the one to ask. Could you install a holding tank and get a septic tanker to pump it?
Ghostmaker is online now   Reply With Quote
Old 04-06-2016, 08:21 PM   #4
Rewards Points: 18,806
No one here has a clue where you are so have no idea what's required in your area.
Any place I've ever lived no home owner should be designing how to do this.
I'd start by contacting a local soil scientist, they can design the whole system with code approved plans needed so you can get bid on having it done.
Around here just the plans would be over $2000.00 then you have to have the county approve the plan before getting any bids.
Old 04-07-2016, 04:15 PM   #5
Rewards Points: 8
look up sewage lift stations. 200 feet is not that far and they have complete lift systems,
I am pumping about 500 feet and have a dual grinder pump system 1 1/4 discharge. Zoeller has a great line and there are about 3 other type brands - just get grinder pump
stevekeen is offline   Reply With Quote
Old 04-08-2016, 06:28 AM   #6
SHEPLMBR's Avatar
Rewards Points: 178
Grinders are not recommended for septic. The solids and liquids need to be able to separate in the tank. Grinders are typically used in forced main sewers. Check with your local health department and they will point you in the right direction. If you have to pump that distance to a septic tank, you will need to use a 2" solid handling sewage pump. If you are dumping into a sewage tank outside the house then pumping into an effluent tank somewhere else then you will need an 1-1/2" discharge effluent pump. Below is the formula to determine TDH. But depending on what your needs/codes are depends on the GPM requirements for your area.
RUN + 50 (to allow for friction loss) = XYZ
move the decimal place back 2 places X.YZ
multiply X.YZ BY 2.06=Y
Y plus LIFT = TDH (TOTAL DYNAMIC HEAD
EXAMPLE:
8 FT OF LIFT
120 FT OF RUN
120+50=170
1.7X2.06=3.502
3.502 + 8=11.5
11.5TDH
SHEPLMBR is offline   Reply With Quote
Old 04-08-2016, 07:34 AM   #7
Rewards Points: 8
Hi Sheplmbr
OK I have a question for you. I am pumping to a sewage line - uphill. I am using dual grinder pumps. The issue I am having is based on dual pumps pumping once every two days for five minutes, I believe that the pumps are only pumping less than 15 hours per year.
I have issues every year with the pumps melting the pvc pipe, continuing to run. Yes the alarm goes off and the light goes on. If we are out of town those alarms do no good.
What type of switch can we use that does not go bad?
The zoeller panel does not stop the pumps if they go for 10 minutes- what type of control panel takes care of this and stops the pumps? Ten minutes is the max amount of time it would take to empty the 1800 gal tank if it were full.
What type of preventative maintenance can be performed and how often?
Thanks for your reply
Old 04-08-2016, 07:39 AM   #8
SHEPLMBR's Avatar
Rewards Points: 178
Hi Sheplmbr
Are you on a force main sewer?
You should have a thermal overload on the pumps. Are they on demand or timed?
Old 04-08-2016, 07:42 AM   #9
Rewards Points: 8
Yes force main sewer. They are on demand, and apparently do not have a thermal overload - one just burnt up.
Steve
Old 04-08-2016, 07:49 AM   #10
SHEPLMBR's Avatar
Rewards Points: 178
Make sure they are sized properly. Also if they are on demand, check your float sensors to make sure that they at the correct height. Also double check your amp load. In your case it may be prudent to get a reputable company out to check it out. A lot of times I get contractors that should know better but don't. They will just throw anything in.
Old 04-08-2016, 07:53 AM   #11
Rewards Points: 8
I think that is what I had, and current guys do not know enough about them. Float switch is not working all the time. Thanks for your help
Old 04-08-2016, 07:55 AM   #12
SHEPLMBR's Avatar
Rewards Points: 178
Yeah float switch placement can be a critical part. And not all pay attention to it.
Good luck!
Leaky Sewage Basin Weakend Warrior Plumbing 12 04-23-2017 10:05 AM
Recent flood-water was gushing through crawl-space foundation where sewage pipe exits DanDaMan Plumbing 5 07-20-2015 02:25 PM
Sewage ejector pump question Jdbrooks Plumbing 5 04-23-2013 07:38 AM
Can I pump sewage ejector pump into horizontal clean out? mnschu Plumbing 10 01-31-2012 06:11 PM
sewage building code for home owners aokss Plumbing 9 09-11-2006 06:37 PM
