Proper Way To Join ABS And PVC - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 07-11-2019, 02:34 PM   #1
Rewards Points: 130
Proper way to join ABS and PVC
To the plumbing experts: what would be the best way for me to connect a PVC sump pump line to the exsiting ABS line? What type of fitting should be used. I also want something than can easily be separated should i need to replace or repair the pump.
cheers
PatFlemming is offline   Reply With Quote
Old 07-11-2019, 04:16 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 2,870
Re: Proper way to join ABS and PVC
Use either an ABS or PVC fitting and use glue compatible to both. https://www.homedepot.com/p/Weld-On-...0274/206534679
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
SPS-1 (07-11-2019)
Old 07-11-2019, 06:10 PM   #3
Rewards Points: 1,252
Use your check valve.
https://www.lowes.com/pd/ProPlumber-...-Valve/1016465
Yodaman likes this.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Gregsoldtruck79 (07-13-2019)
Old 07-11-2019, 09:20 PM   #4
Rewards Points: 1,750
Use a threaded connection.
The combination ABS/PVC glue will not pass code for a reason.
ktkelly is offline   Reply With Quote
Old 07-11-2019, 09:26 PM   #5
retired framer
Rewards Points: 16,100
They make it ease out here, sewer lines are ABS and storm sewer is PVC and septic fields, the two never meet.
Do not use flat bottom gables with scissor trusses.
Old 07-12-2019, 08:15 AM   #6
Rewards Points: 1,853
Would something like this work?
huesmann is offline   Reply With Quote
Old 07-12-2019, 08:24 AM   #7
Rewards Points: 130
That's what I was hoping for. It would
Make disconnecting in the future much easier. Is a rubber sleeve with clamps suitable for PVC to abs?
Old 07-12-2019, 09:19 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 518
That will blow off under pressure, intended for drain lines.
Use a PVC or ABS union and transitional cement.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 07-12-2019, 09:21 AM   #9
Rewards Points: 130
This is for a sump discharge line
Im thinking going with the following
https://www.homedepot.ca/product/pro...1-2/1000450792
Old 07-12-2019, 11:00 AM   #10
Rewards Points: 130
Originally Posted by Ghostmaker View Post
that's a good call but my new pump comes preassembled with a checkvalve.
Old 07-12-2019, 11:30 AM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 518
The pressure from the pump can blow that off. You need a union.
Sent from my Moto E (4) Plus using Tapatalk
Old 07-13-2019, 03:02 AM   #12
Rewards Points: 214
This would be against most local codes. Where allowed, this cement is only approved for a connection in a low pressure drain/waste/sewer connection, not for general use. At least that has always been my understanding.
Abuc is offline   Reply With Quote
Old 07-13-2019, 07:08 AM   #13
Naildriver
chandler48's Avatar
Well, duh, that's what he is connecting. It will hold far better than a fernco at any rate.
Larry......
Old 07-13-2019, 07:41 AM   #14
Rewards Points: 214
OP was asking about his sump pump line which includes the check valve. This is a pressure system, duh.
Old 07-13-2019, 07:49 AM   #15
Naildriver
chandler48's Avatar
He must have solid connections. A fernco won't work. The only solution he has is to use glue made for the transition materials. I don't know of any "codes" that prohibit the use of these glues and materials. The pressure he will be experiencing is short lived and not up to 65 psi as house water would be on a pressure line.
Larry......
