Proper Drain Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2018, 05:12 PM   #1
Rewards Points: 2
Proper drain vent
Will a 2" pvc dwv pipe be sufficient for a vent for a bathroom with 1 sink, 1 toilet and a shower ?
RunTheTools is offline   Reply With Quote
Old 03-11-2018, 05:44 PM   #2
Rewards Points: 1,952
Re: Proper drain vent
Depends on what code your under and where you place the vent?
Old 03-11-2018, 06:18 PM   #3
Rewards Points: 2
I believe I'm under the UPC in San Antonio Texas.
I am pretty much copying the previous existing cast-iron dwv layout and pipe size.
The vent comes out the back of a 3x3" bend with 2" low heel inlet. Which flows down to a 3x3 x2x2 double wye, where all three pipes meet. The shower originally had its own inch and a half vent pipe. But I wanted to know if I can tie it into the main 2" ? I provided a couple of photos, please excuse the crudeness.. Thanks !
Proper drain vent-img_1266_1520810261254.jpg   Proper drain vent-img_1267_1520810273938.jpg
Old 03-11-2018, 06:54 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 290
Not in your current lay out. I believe the toilet must be the first fixture when horizontal wet venting. You can confirm that with your inspector.
I do know that in my area (UPC), double wyes are not approved in the horizontal though.
With the layout you have now, replace the dbl. y with two 3x2 wyes. and vent the shower as you did the toilet. Then tie the 3 vents together in the wall @ 42" off the floor. Take one 2" vent through the roof.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Ghostmaker (03-12-2018), RunTheTools (07-14-2018)
Plumbing Book Reccomendations patrickpresti Plumbing 173 02-04-2016 06:15 PM
Is this a vent or an additional drain? Smahoney6 Plumbing 16 01-30-2016 12:03 AM
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 07:14 PM
Drain and Vent Layout Help jkg81 Plumbing 18 10-07-2013 08:36 PM
Proper drain and vent help needed papisox Plumbing 17 11-03-2010 08:52 AM
