Propane Pipe Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2015, 03:24 AM   #1
Rewards Points: 12
Propane Pipe Size
I recently replaced old copper tubing in my house with CSST. I have only a dryer and stove being fed. I ran 1/2 inch into the house about 12 feet to a tee fitting which branches off 10 feet to the dryer and about 10 to the stove. I realized after i connected everything that the old copper was 3/8 and not 1/2. Will this difference in my tubing affect pressure to my appliances at all?
ozzlvlosis is offline   Reply With Quote
Old 01-15-2015, 04:56 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,324
Nope,.... Pressure is set by the regulator,...
The larger pipin' just allows better flows,....
Old 01-15-2015, 09:27 AM   #3
If you had re-piped with smaller pipe you could have had pressure loss due to friction caused by the smaller pipe. However, since you installed larger pipe, and as long as it is sized correctly, you should be ok. If I remember correctly, 1/2" CSST sizes similar to 5/8" copper.
hvac benny is offline   Reply With Quote
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
what size pipe to use for water main? Cainiac Plumbing 5 04-24-2012 11:57 PM
toilet/sewer pipe size venting cdhoustonusmc Plumbing 3 12-11-2011 10:19 AM
Using sharkbite to fit leak in pipe...pipe hole size question. RyanD Plumbing 4 08-14-2009 06:17 PM
Pipe Size pochi Landscaping & Lawn Care 2 07-04-2009 03:13 PM
