Propane Configuration - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2015, 11:43 PM   #1
Rewards Points: 12
Propane configuration
Ive attached a picture. I wanted to know if it's ok if that from the Tee fitting, this csst tubing is going up and back down to the shut off valve. Does this have any effect on the pressure within the tubing?
I ask bc I just replaced an old dryer not too long after i replaced the old copper tubing with csst. It was firing up intermittently and emitting a not quite gas smell from within about a day after doing a load.
I just bought a new Hotpoint dryer and converted it to propane. Just curious if i should leave this configuration before i hook the new one up. Thank you for reading.
ozzlvlosis is offline   Reply With Quote
Old 03-18-2015, 02:00 AM   #2
Rewards Points: 6,608
It won't effect dryer operation. I'm not certain what a " not quite gas smell is " but do check for leaks with a liquid detergent / water solution.
Old 03-18-2015, 11:25 AM   #3
Rewards Points: 12
The best way to describe it was Truffle. It didnt have the rotten smell propane has but it did smell like gas.
It would happen exactly a day after doing a load. Anyway thats gone. Just wanted to make sure this tubing going up into a loop had nothing to do with the pressure. Thank you.
The Following User Says Thank You to ozzlvlosis For This Useful Post:
SeniorSitizen (03-18-2015)
Old 03-18-2015, 09:38 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
drop test the system.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 05:23 PM
Filling a 20lb propane cylinder off a 1000 gallon tank--anybody done it? jbeall Building & Construction 26 12-27-2011 11:30 PM
chimney liner, excuse for propane furnace upgrade? bubbler HVAC 0 09-16-2011 07:58 AM
gas (propane) cooktop off a BBQ tank pstock Appliances 0 06-26-2010 09:21 AM
