Problem Removing A Tub Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2016, 11:43 PM   #1
Rewards Points: 4
Problem removing a tub spout
Hello. I am running into a problem with my tub spout from a tub / shower combo. The faucet is a Delta if that matters. Unfortunately I do not have any of the paperwork from the install to determine a model name or number.
This tub spout has the pull up / push down type of diverter at the far end. It is sticking and very difficult to move, so I believe I need to replace the spout.
The spout appears to be a slip on with a set screw. Normally this should be really easy to remove, but it appears the set screw is about 60 degrees rotated from the slot in the bottom of the spout. I can see the side of the screw head through the slot, but there's no way to get a screwdriver to engage the screw head in order to loosen the screw. The screw is too far into the spout to reach the head with a needle nose pliers. Additionally, I can rotate / spin the spout on the copper pipe coming out of the wall but cannot slide it off the pipe.
Attached is a phone picture through the slot of the spout showing the side of the screw head.
Question is, what can I do to remove the spout if I cannot get a screwdriver into the set screw head? No idea what to try.
Thanks.
EffinIllini is offline   Reply With Quote
Old 03-28-2016, 07:47 AM   #2
Rewards Points: 352
Re: Problem removing a tub spout
why don't you turn the spout until it lines up with the set screw, if the pipe is turning just unscrew the whole assembley.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
SHEPLMBR (04-05-2016)
Old 03-28-2016, 08:20 AM   #3
Rewards Points: 4
I can spin the spout all around the pipe, but the set screw spins with the spout in the same position relative to the slot in the spout. I can't spin the spout to line the slot up with the set screw.
The pipe is not turning with the spout.
Old 04-01-2016, 05:45 PM   #4
Rewards Points: 8
The ones I've removed did not have a slotted screw, it's an Allen head set screw. You need a set of Allen wrenches. Once you back the set screw all the way out it should slide right off.
ScooterBiggs is offline   Reply With Quote
Old 04-01-2016, 06:06 PM   #5
Rewards Points: 10,464
Scooter is right. Likely Allen Head.
SPS-1 is online now   Reply With Quote
Old 04-01-2016, 09:37 PM   #6
Rewards Points: 258
just take a screwdriver and pry the piece with the set screw over to the opening..
woodchopper65 is offline   Reply With Quote
Old 04-03-2016, 06:11 AM   #7
Rewards Points: 2,560
I'm with Woodchoppers' idea.
bob22 is offline   Reply With Quote
Removing Stubborn Tub Spout 347Cougar Plumbing 6 12-27-2012 03:12 PM
Frustrating bath spout removal problem martinvancouver Plumbing 6 07-09-2009 12:38 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Tub spout diverter problem Chaosdragon13 Plumbing 2 05-28-2008 12:23 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
