Problem Removing Faucet Handles - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2014, 05:02 PM   #1
Problem removing faucet handles
I'm trying to fix a drip in my bathroom faucet. The faucet handles don't appear to have a set screw, or a cap that I can remove to access the set screw (I've checked the backs and sides of the handles). I don't see any manufacturer information, though the spout has Perlator VX stamped on it (searching this name hasn't really helped me). Any ideas on how to remove the handles?
I can't post links yet, but here are images of the faucet:
i.imgur.com/l6J7kE1.jpg
i.imgur.com/eOW60Aa.jpg
i.imgur.com/iyiveyY.jpg
shakingspear is offline   Reply With Quote
Old 03-20-2014, 05:32 PM   #2
Rewards Points: 5,648
I can't help you at the moment but the first manufacturer that makes a fixture with miniature Vise Grips for handles will be on the top of my purchase list for consideration.
Make it for looks - Make it for life
Old 03-20-2014, 06:18 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 180
While holding the handle so it won't rotate- try to turn the bottom portion counter-clockwise.
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
gregzoll (03-20-2014), oh'mike (03-20-2014), shakingspear (03-24-2014)
Old 03-20-2014, 06:23 PM   #4
Retired Moderator
Rewards Points: 7,174
Is that a three piece set---desperate spout and two valves? If so--E-Plumber has the answer---the bell shaped part below the handle unscrews
Old 03-24-2014, 12:40 PM   #5
Just wanted to thank you guys for the advice. After a lot of trying to twist off the base, I found that the handle just pops right off. It's a Glacier Bay Leonardo sink from Home Depot, in case anyone in the future has this same problem.
The Following 2 Users Say Thank You to shakingspear For This Useful Post:
jdearie (12-27-2015), oh'mike (03-24-2014)
Old 10-31-2015, 12:34 PM   #6
Rewards Points: 2
Removing perlator faucet handles
The handle is a snap-on. Grip the handle firmly, and work back and forth quickly a few times to loosen. Then, still gripping firmly, lift up.
HelpingHandJob is offline   Reply With Quote
Old 12-27-2015, 12:41 PM   #7
Rewards Points: 6
I was able to pop off the handle... removed the screw and the plastic covering, but I can't seem to get the stem(?) out to replace it. I swear I'm doing something wrong, but I can't seem to loosen anything else, and it won't just pull out like the 20 youtube videos I've watched. Ideas anyone??
Problem removing faucet handles-img_4679.jpg   Problem removing faucet handles-img_4678.jpg
jdearie is offline   Reply With Quote
Old 12-27-2015, 12:45 PM   #8
Retired Moderator
A new thread for your problem is wise--few members look at an old thread like this.
However, you need to remove the C-clip---ti is the bit of wire above the backing nut--around the shaft of the stem--
Gymschu (12-27-2015)
Old 12-27-2015, 01:41 PM   #9
Rewards Points: 6
Thx - I'll start a new thread... I did pull the clip off, but still can't get the stem out.
Shower faucet handles sometimes squeak a steam sound daluu Plumbing 0 10-26-2012 12:04 AM
Replacing old Delta Roman Tub Faucet InvaderZim Plumbing 0 10-16-2012 06:53 PM
Need help removing a difficult old kitchen faucet tsand72 Plumbing 7 02-17-2012 05:49 PM
Removing this type of supply line from bathroom faucet? dveiga Plumbing 5 04-24-2011 08:58 AM
cartridge faucet problem. drewhart Plumbing 4 01-15-2009 10:49 AM
