Private Well Water - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 05-08-2017, 05:08 PM   #16
Rewards Points: 898
Re: Private Well Water
Originally Posted by rjordan393 View Post
Thanks follows,
I am a city person and been drinking and bathing with public water all my life and I do not recall ever drinking private well water. So thanks for the education. I will stick with public supplied water.
Then this thread is dead.
BIG Johnson is offline   Reply With Quote
Old 05-09-2017, 09:53 AM   #17
Rewards Points: 122
Originally Posted by BIG Johnson View Post
Tell that to residents of Flint.
Point I was making is it's not impossible to have a lab test your city water.
Joeycarnuba is offline   Reply With Quote
Old 05-09-2017, 10:24 AM   #18
Rewards Points: 6,378
Codes are common and I disagree with some that seem to me rather, not necessary, but to me it should be illegal to even list a piece of property with a well without a passing grade by state/county/health inspection and the paper work filed in that county with the deed or whatever legal documents your state county has for said property.
Old 05-09-2017, 04:42 PM   #19
Rewards Points: 898
I was referring to your second sentence.
"The EPA requires the public water provider to meet certain requirements through the Safe Drinking Water Act, it's the law."
Either way, it doesn't matter anymore because OP doesn't want a house with well water.
Old 05-09-2017, 05:08 PM   #20
Rewards Points: 695
Yes that's correct.
But I like to state that well water does have its faults. It may taste good now and after say 3 months, it still taste good, then if impurities are leaking into the well, then by the time you noticed something wrong with the water,
then it's too late when your family becomes sick.
rjordan393 is offline   Reply With Quote
Old 05-29-2017, 07:46 AM   #21
Rewards Points: 48
That's why you put a whole house filter on it, it's pretty cheap.
anony is offline   Reply With Quote
Old 05-29-2017, 08:51 AM   #22
Rewards Points: 1,932
Why don't you ask the Democrats in charge of Flints water system?
I assume you never brush your teeth to avoid the fluoride?
Help with hot water katiejosh811 Plumbing 13 12-28-2016 05:52 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
