Price Pfister Shower Leak - Help - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By SeniorSitizen
Old 11-15-2017, 07:21 AM   #1
Rewards Points: 2
Hi all, I have a problem I cannot solve. We have a Price Pfister shower fixture. It was leaking at the shower head. I replaced the two- piece valve assembly, which consists of a balancer cartridge and the mixing unit that attaches to the handle. That seemed to fix the constant drip. However, we have a recirculating pump for our tankless water heater and whenever the pump goes on the shower drips again. I know it's not a defective cartridge or mixer because I bought another set and had the same problem. I've tried silicone grease and other solutions with no luck. Any ideas about why it would continue to drip when the recirculating pump goes on?
Thanks!
Matt
Matthew123456 is offline   Reply With Quote
Old 11-15-2017, 07:29 AM   #2
Rewards Points: 6,600
Re: Price Pfister Shower Leak - Help
Hot water expansion of a Price Pfister component. Try lowering the temperature 10 - 15 degrees.
Nealtw likes this.
SeniorSitizen is offline   Reply With Quote
Old 11-15-2017, 08:13 AM   #3
Rewards Points: 18,998
Is there an expansion tank plumbed into the line?
Old 11-15-2017, 09:39 AM   #4
Rewards Points: 2
I'll try lowering the temp but the odd thing is that I didn't have this problem with the original components.
Old 11-15-2017, 09:39 AM   #5
Rewards Points: 2
No I don't have an expansion tank.
Tags
pfister , recirculating , shower
maax shower leak debb Plumbing 2 07-20-2012 07:45 AM
Price Pfister Parisa Shower Anti-scald valve fails to scald position Naval Aviator Plumbing 1 01-28-2011 12:40 PM
