Prevent Leaking In Toilet Line Supply Line? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 3 Post By hkstroud
Old 11-15-2016, 05:28 PM   #1
Rewards Points: 4
Prevent leaking in toilet line supply line?
I've just replaced the fill valve on a toilet and after hand-tightening (firmly) the coupling nut, I'm getting leaking. I've attached a photo. It appears there is a metallic washer which surprised me, I expected something elastic, but I'm not a plumber so I don't know. I also wiped the interior of the tank to make sure no debris got between the tank and the rubber shank washer that came with the kit. Photo attached.
Am I missing something? Seems if I wrench-tighten this I could crack the plastic.
Thanks!
bethesda99 is offline   Reply With Quote
Old 11-15-2016, 07:09 PM   #2
hkstroud's Avatar
Rewards Points: 6,684
Re: Prevent leaking in toilet line supply line?
That appears to be the end of an old chrome hard supply line or a polybutle supply line that someone jerry rigged a compression nut for.
Discard it. Go to Home Depot, Lowe's or any hardware store. Purchase a braided flexible toilet supply as shown below. Be sure that you purchase toilet supply line and not a faucet supply.
Measure before you go. They come in certain lengths and cannot be shortened. Shortest is 9".
They use rubber washers and O rings to seal and are easy to install. God's gift to plumbers.
joecaption, 123pugsy and supers05 like this.
hkstroud is offline   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
bethesda99 (11-16-2016)
Old 11-16-2016, 04:34 AM   #3
Rewards Points: 4
Appreciate it!
Old 11-16-2016, 06:46 AM   #4
Rewards Points: 1,274
Hand tightening depends on each hand. I got a fair grip but also give it a quarter turn with a wrench. My hand tight is when I can't turn the nut by hand.
carpdad is offline   Reply With Quote
Toilet Still Leaking After Replacing Gasket, Bolts, Fill Valve, Flush Valve wheeee Plumbing 24 08-11-2017 08:57 PM
leaking main supply line from street alpinekid Plumbing 0 07-07-2012 02:52 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
