Pressure Tank Has Pressure Faucet None - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-16-2016, 09:31 AM   #1
Pressure tank has pressure faucet none
I have excellent pressure at my pressure tank. The rest of the house has nothing. The gauge reads 64lbs and the outlet there flows water like crazy. I have no valves turned off and I have no leaks. I'm stumped.
Jake802 is offline   Reply With Quote
Old 09-16-2016, 09:46 AM   #2
Rewards Points: 5,424
Re: Pressure tank has pressure faucet none
Is the system attaining pressure and cycling normally as you flow water at the outlet you describe?
Old 09-16-2016, 11:37 AM   #3
Yes, it's recovering what I use from the outlet. I hooked a hose to it to fill up some water buckets. Gauge dropped when used but came back up to 64 psi as usual.
Old 09-16-2016, 11:44 AM   #4
ZTMAN's Avatar
Rewards Points: 604
If no valves are shut and no lines are broken, try resetting the pressure-switch. Every time we have no pressure at our camp, that what the well guy tells me to do and it seems to work. Kind of like re booting a computer.
It is high voltage, so make sure you know how to reset.
ZTMAN is offline   Reply With Quote
Old 09-16-2016, 11:46 AM   #5
I have a breaker for it. I've flipped it a few times. I'm stumped
Old 09-16-2016, 11:47 AM   #6
ZTMAN's Avatar
Rewards Points: 604
Its not the breaker, its a lever on the switch
Old 09-16-2016, 11:49 AM   #7
ZTMAN's Avatar
Rewards Points: 604
Should look like this:
Old 09-16-2016, 02:57 PM   #8
Rewards Points: 167
Do you have a water softener or whole house water filter downstream from the pressure tank? If so, check them for clogs. Also, remove the ariator from the
one of the spigots to see if they are clogged. I've seen debris and
dirt pumped into the water system that entirely shut down the water flow in the house plumbing but not at the pressure tank.
kb3ca is offline   Reply With Quote
Old 09-16-2016, 05:44 PM   #9
Super Moderator
joed's Avatar
Rewards Points: 31,584
The pump is building pressure. Don't waste your time looking for electrical issue. You have a clog somewhere. Either a valve you didn't know about or a filter that is clogged. If you have galvanized pipes one could be rusted shut.
Is it both hot and cold? If it is then the issue is early in the system before the feed to the hot water tank.
Old 09-16-2016, 08:51 PM   #10
Its both hot and cold that doesn't have pressure. There is one pipe that runs to the hot water. It's all relatively new PVC. I can visually see the pipe, the outlet that I can draw off is right before it. I have plenty of water and pressure from it. No faucets are clogged as they're half missing screens. I don't have any filtration systems. I'm completely stumped on this. I've replaced the pressure switch, the well pump.
Old 09-17-2016, 03:06 AM   #11
If you haven't done so, I recommend shutting the water heater off until this problem is resolved.
Consider trying this if you haven't. Put a hose on the water heater drain and monitor the well pump for operation while attempting to drain the tank. That may be the closest valve after where you are experiencing flow. If you are getting flow the pump should cycle and you'll know water is getting into the tank and that would be 1 step closer in solving the mystery.
Old 09-17-2016, 08:11 AM   #12
Super Moderator
joed's Avatar
There is nothing wrong with the pump. He has said he has one outlet that gives water and the pump cycles on and off as the water is used.
The problem has a blockage in the plumbing. He just needs to find out where. Since he also has no hot water, the blockage has to be in the section between the tank and the water heater.
Unless he has multiple blockages, before and after the hot water tank, this should be simple to find.
Old 09-17-2016, 09:09 PM   #13
Rewards Points: 3,258
I would suggest turning off the water heater heat if you are getting no flow at all from hot faucets.
You don't want the tank to empty out due to siphoning or other reason after which time the water heater will self destruct if it kicks on.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 09-19-2016, 11:30 AM   #14
SHEPLMBR's Avatar
Rewards Points: 178
The switch in this video is a low water cut off switch. Not typically used. Your pressure in your tank should be 2psi lower than your cut on pressure.
SHEPLMBR is offline   Reply With Quote
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
pressure tank problem? steel Plumbing 14 07-03-2008 02:06 PM
