Pressure Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2017, 07:04 PM   #1
Rewards Points: 4
Pressure Tank
I have a pressure tank for my well that is holding air and i replaced the pressure switch but the tank wont engage any suggestions?
Irishluck is offline   Reply With Quote
Old 01-03-2017, 07:14 PM   #2
Rewards Points: 6,404
Re: Pressure Tank
I'm not familiar with the term " tank won't engage ".
If the tank pressure is approximately 2# below switch cut in pressure and the draw down volume is approximately what the manufacture for that tank rates it, the tank is doing its job.
SeniorSitizen is offline   Reply With Quote
Old 01-03-2017, 07:19 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,298
Re: Pressure Tank
+1
Are you talking about the pressure switch that energizes the pump or are you saying that no water is even coming up?
Old 01-03-2017, 07:31 PM   #4
Rewards Points: 4
Re: Pressure Tank
i have water just no pressure the gauge on the tank sits at 0 therefore the pressure tank wont cut in (start)
Old 01-03-2017, 07:37 PM   #5
Re: Pressure Tank
Hopefully this link will help.
http://inspectapedia.com/water/Water...pair_Guide.php
Elevated pressure tank rich_kildow Plumbing 4 12-29-2013 04:10 PM
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Pressure tank cycling sontavas Plumbing 8 12-10-2012 07:04 PM
New Well, Pump & Pressure Tank Design Daneel Plumbing 0 06-07-2011 03:28 PM
pressure tank problem? steel Plumbing 14 07-03-2008 02:06 PM
