Pressure Switch Vs Low Pressure Switch - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2016, 07:24 PM   #1
Rewards Points: 40
Pressure switch vs low pressure switch
My current well set up has two low pressure switches. There is one controlling the pump in my aerator tank which pumps water into the house. There is another that controls the pump in the ground which pumps water into the aerator tank. Twice in the last two days my aerator tank has not filled. The low pressure switch that controls the in ground well pump has kicked off. I understand why the aerator pump needs the low pressure switch, for this very situation. I cant understand why the in ground well pump needs the low pressure switch. Should that just be a regular pressure switch, that does not have the ability to kick off. I have attached pics of the setup as well as the two low pressure switches. I look forward to your suggestions.
Pressure switch vs low pressure switch-img_0071.jpg   Pressure switch vs low pressure switch-img_0072.jpg   Pressure switch vs low pressure switch-img_0073.jpg
cap33905 is offline   Reply With Quote
Old 09-28-2016, 08:23 AM   #2
SHEPLMBR's Avatar
Rewards Points: 178
Re: Pressure switch vs low pressure switch
They are not commonly used. But in this example, I am clueless. I have never seen anything like it here in NOVA
SHE-PLMBR
SHEPLMBR is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 07:53 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
