Pressure Relief Valve Noise - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 12-26-2017, 03:38 PM   #16
Rewards Points: 34
Re: Pressure relief valve noise
Originally Posted by joecaption View Post
Still no reply about that the incoming pressure is.
Simple to check.
Just connect one of these to an outside faucet.
https://www.homedepot.com/p/Rain-Bir...-P2A/100575619
I would have disconnected the line attached to the valve long ago to see if it's truly leaking.
If it is and the pressure is under 50 PSI the manufacture would be willing to replace the valve, or do it yourself, simple cheap fix.
A friend is coming by tomorrow with a gauge to check pressure. This is a gas hot water heater.
Pressure relief valve noise-bottom-half-hot-water-heater.jpg   Pressure relief valve noise-full-picture-hot-water-heater.jpg
dtpga is offline   Reply With Quote
Boiler losing water through pressure relief valve diy888 HVAC 7 11-21-2016 03:12 AM
Pressure relief valve lemley98 HVAC 2 07-23-2016 12:41 AM
Boiler pressure relief valve problem maddog1 Plumbing 25 12-22-2012 07:35 AM
pressure relief valve broken ? davisdave Plumbing 6 10-07-2012 04:22 PM
Boiler pressure relief valve leaking Jaschance HVAC 3 02-08-2010 10:05 PM
