Pressure Relief Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2016, 11:13 AM   #1
Rewards Points: 109
pressure relief valve
Pressure relief valve on hot water tank was installed and is slightly cocked towards the left. If a back it off a little to add drain pipe am I chancing a leak?
hitmehhh is offline   Reply With Quote
Old 09-21-2016, 11:50 AM   #2
Rewards Points: 5,542
Re: pressure relief valve
Backing off a little usually doesn't cause leaks if teflon tape was used on the threads.
On high pressure fittings I limited reversing to a quarter turn.
Old 09-21-2016, 01:23 PM   #3
Rewards Points: 3,220
Agree with senior. If no tape was used, turn wh off, drain a few gallons till its under prv, uninstall prv and reinstall it using tape. Stop at the correct position. Ezpz 123Z.
If its just slightly crooked and you can live with it, just leave it alone.
Post a picture of it. Thanks.
jmon is online now   Reply With Quote
Pressure relief valve lemley98 HVAC 2 07-23-2016 12:41 AM
Replacing a Pressure Relief Valve for a Boiler multiphrenic HVAC 18 11-30-2011 11:16 AM
Water leaking from boiler pressure relief valve gottaknow HVAC 4 12-10-2010 12:06 PM
in line pressure relief valve hidden 1 Plumbing 2 02-22-2009 04:52 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
