Pressure Reducing Valve Chatter - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2016, 07:17 PM   #1
Rewards Points: 32
Pressure reducing valve chatter
I recently bought a new home and noticed when I first turned the water on there was a sudden burst of water so I installed an expansion tank. After installing the tank it didn't seem to help so I test the water pressure and it's coming in at a whopping 160, however when I let water regulate after letting it run it would go down to about 80 so I reduced the pressure down to about 60. The problem is the pressure when nothing is running has remained at 160, so I'm thinking maybe the Pressure reducing valve is going bad. The new issue, 2 days after installing the expansion tank is that the pressure reducing valve will random chatter or vibrate for about 20 seconds. Am I right I thinking the reducing valve is going bad?
On a separate note what psi should the expansion tank be set at, it's currently at 25 should it be closer to the 60
Roger0205 is offline   Reply With Quote
Old 01-25-2016, 08:49 PM   #2
Rewards Points: 3,452
Yes. I agree your pressure reducing valve sounds suspect.
Expansion tank should be set at the incoming water pressure. Like you said, about 55-60psi.
jmon is offline   Reply With Quote
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Pressure Relief Valve Leaking new_DIY Plumbing 10 10-04-2012 10:24 PM
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 05:36 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
do Pressure Reducing Valve fail? wazeaz Plumbing 5 02-10-2008 05:57 AM
